25th gear
Old Mar 1, 2010 | 08:12 PM
lagunatic's Avatar
lagunatic
Default 25th gear
I bought a 72 FLH about a month ago it felt a little slugish and had a fadeing lose of power going up hill ihave since did a run thru and tune up as per the manule and all checks out good .starts great. runs great.so after reading a post about gearing I thought I would give them a check and found a 25 th drive and 51 at the wheel and I was thinking their lays the problem I want to ride 60 to 70 with a passenger with out that lose of up hill power so 24 or 23 th that is the question.any help would be great
Old Mar 1, 2010 | 10:48 PM
11sec.shovel's Avatar
11sec.shovel
Wow! 25 tooth trany sprocket? Dont know f ive ever seen such a monster. Seems like it would rub on the top (return side) of inner primary. 23 or 24 would def. help. 23 t would net you 2800 rpms @60mph. However, thats when the old shovels start to really buzz your hands and a few other body parts. Its a tough trade off between power and higher cruseing speeds with only 4 gears. Good luck and enjoy your shovel
Old Mar 2, 2010 | 06:42 AM
93ci.sh's Avatar
93ci.sh
6th Gear
I ran 25 tooth on the front 48 tooth on the back it flys it's sill got great take off I get 60km first gear 90km second 130km in third 180km in top gear.I have a1984 FLH box in my 79 lowrider it help to have a 93ci motor.I don't ride like is all ways I like my licence
Old Mar 2, 2010 | 11:36 AM
megawatt's Avatar
megawatt
The standard sprocket on FL and FLH models was a 22 tooth as I recall.
It was that way because it was expected that the bike would have the weight of the bags and fairing for touring.
Regardless of what was stock, if you want great acceleration around town and the ability to pull hills loaded down with touring stuff, try a 22 tooth.
Old Mar 3, 2010 | 04:35 PM
78fxs78's Avatar
78fxs78
I have 23 front and 47 rear, puts me at around 3k at 70 mph on my FLH and 23/48 on my FXS
john1dup
Shovelhead
Mar 10, 2012 12:55 PM
john1dup
Mar 3, 2012 06:36 PM
lagunatic
Shovelhead
Feb 8, 2010 11:57 AM
foxlakerider
Shovelhead
13
Jan 22, 2010 10:05 AM
Schlebusch
Shovelhead
Aug 27, 2007 09:27 PM
