80 Wide glide rear brake problem
Bob
That could change things.
Was there any master cyl work????
I think there may well have been.
There is a small hole in the m/cyl that allows the fluid to move back and forward between the bore and the reservoir.
If the wrong kit is installed, and the rubber boot is too long, or too far forward, so that it covers the hole, the fluid can only pass one way.
This is easy to check, if you have a combination reservoir/bore m/cyl.
With the lid off, if you press the pedal quick, you should see a jet(possibly small, but maybe large, so take care) of brake fluid shoot up into the reservoir. This is the fluid being displaced before the boot passes the hole, and pressurization commences.
Of course, if the boot is already past the hole, there will be no jet at all.
You need to check a few things.
Of course, as many would know, sometimes the jet will come flying right out, and go all over your paint.
Many adhere to the rule that you do not blow compressed air through a brake line, as oil/moisture in the air gives a problem. Perhaps with modern machinery this is not such a problem, but it used to be.
Air is useful in all this, however, and I use it in the lines, but I have a good compressor system.
You need to make sure that every aspect is correct.
As in, is the rotor bent?
Is my caliper correctly mounted?
Is my caliper full of dried gunk and crusty bits?(common)
Is my brake line old, and internally collapsed?(common with the original rubber type)
Has my brake fluid been in there for forever?
Are the adjustments on my foot controls allowing correct operation?
Is my master cyl clean, with the right kit installed?
With a few basic tools, you could have that apart in a short time.
Just have at it.
Whether or not you need a kit, or whether or not a kit will suffice, will not be known "for sure" until you pull it all apart.
You should try to develop a habit of extreme thoroughness in addressing any problem, thereby fully eliminating any further issues from that area.
With the year/model you own, this is almost a service procedure.
If all looks ok from a "mechanical" viewpoint(meaning adjustments and the like) you need to take the m/cyl apart , and see what kind of shape it is in.
If it is all corroded in there, a new m/cyl could be the go.
It may be in good shape, including the internals, and you can just clean up and go again. Might just be gunky. A good cleanout, and it could last for years. You don't know until you look.
I know it will take longer to not order the parts first, but you really do not know what you need right now.
If you get stuck, just post here.
I have no doubt that there are many who know the answers you need.
Of course I/we/they will help you, if possible.
I took it for a test ride after flushing the sytem clean......and the problem did not come back. I only rode the bike 2 or 3 miles but it didn't seem like problem was coming back at all. the pedal stayed the same.....did not get hard like it did before. The brakes did not drag. Maybe I need to ride it a few more miles but It seemed like before after about a mile the brakes started to drag. I got home and felt the brake caliper.....it was hot....so here is my next question.....How much heat are these brakes supposed to make? The calipar was warm, the disc was hot. Is this normal, not sure how much heat the brakes are supposed to produce.
when the brakes were dragging before they were searing hot....couldn't even touch them.
But as long as the brake is working fine, and the disc is not turning blue, and not dragging, it is all fine.
"junk" can definitely be the problem.
Dot 5 always starts out purple. This is a product trait, not just brand. This means it is fresh.
As it ages, it becomes clear, and then yellow.
Yellow means it is way too old.
Clear means you should certainly change it, but it is not a disaster.
If there was no sign of the "jet", and now there is, it looks like you may have cleared an obstruction.
You just have to be careful about doing "long" bleeding strokes, as corrosion often builds up in areas where the piston does not normally travel, and can cause damage to the rubber cup when it is moved further down the bore than usual.
But if it is working well, then all good.
