Shovelhead module
Old Apr 26, 2010 | 07:19 AM
Dukeboy's Avatar
Dukeboy
Default Shovelhead module
I just got an 82 FLH with no spark, I ordered a twin tech module, with the cup installed I put the module in and I'm getting no flash on the module. I checked for voltage on the coil checks good. The coil is a new 5 ohm. I'm not sure I have top dead center but I should still get spark? I am definatly a bigginer so any assistance would be helpful.
Old Apr 26, 2010 | 06:04 PM
otlawpan's Avatar
otlawpan
Which module did you get, I was trying to look them up and couldnt figure out which goes on an 80's bike?
Old Apr 26, 2010 | 06:17 PM
otlawpan's Avatar
otlawpan
I dont know about that specific ignition but most can be started if you center the plate. if youre not getting spark or a light on the box, double check the connections, also Ive gotten bad ignitions right out of the box, from different manufactuers. did it start before you put the new ignition on it?
Old Apr 26, 2010 | 07:17 PM
travelinghunt's Avatar
travelinghunt
4th Gear
Default Used my budies loggin, now I'm here.
Its a Datona Twin Tech model 1005. I'm new to the bike. Just bought the bike a week ago. I was told it was stored for two - two and half years.
I am thinking I have gotten a new BAD module.
Old Apr 26, 2010 | 07:21 PM
travelinghunt
4th Gear
Default Module install
I had to retrofit the cup in order to install this module. I am was told the motor was rebuilt just before it was stored. Turns over like a champ! Just no spark.
Old Apr 26, 2010 | 09:02 PM
megawatt's Avatar
megawatt
Daytona TwinTec says the 1005 module requires the use of a 3 ohm single fire ignition coil.
Perhaps you should go to their website or call them for complete info on how to set up your ignition.
Old Apr 27, 2010 | 09:33 PM
otlawpan's Avatar
otlawpan
Yes, single fire ignition requires a single fire coil, or dual coils, if your using the old coil that may be your problem.
Single fire fires one cylinder at a time, dual fire fires both cylinders.
Old May 19, 2010 | 06:57 AM
Dukeboy's Avatar
Dukeboy
You should try checking your battery terminals...
Old May 25, 2010 | 08:39 PM
travelinghunt
4th Gear
Default Moron
I am I got the bike was excited got the bike and took it for granted the dealership (with year, model, and VIN) would give me the right battery and was in a hurry. I slapped the battery in and it was reverse polarity!
I'm a moron!
Thanks for the good advise!
jim70
Shovelhead
Jan 21, 2017 11:51 PM
Cup
Softail Parts
Jan 25, 2016 12:29 PM
badinfluence63
Aug 8, 2008 09:01 AM
redtruck
Shovelhead
Jun 22, 2008 10:24 PM
Gumby256
May 25, 2008 01:16 AM
