Points
Old Sep 1, 2006 | 08:56 PM
JAMES2's Avatar
JAMES2
Default Points
Any ideas on why my points might spark sometimes and other times notta?
I got fired up, it ran for about 4 min. and quit just like someone hit the kill switch.
Any thoughts?
Old Sep 2, 2006 | 11:40 AM
mikeyhd's Avatar
mikeyhd
Default RE: Points
hmmmmm.... let's look at this from a basic electrical "points" (get it?) of view... (sorry bout that).
Ignition circuit overview: Battery > key switch > kill switch > points > coil > plug wire > plug > engine block > frame > battery
The points system uses a set of contacts that make and break 12vdc to a coil, the coil then ups the voltage and sends it to the plugs. The spark tells you that current is flowing and that can only happen when there is a complete circuit (path). While the contacts are closed current flows through them. As they open the current must now momentarily flow through the air until the gap is so huge that current stops flowing, and that is pretty much what causes the "spark" you are seeing.
I converted my bike to an electronic iginition 14 years ago but if I recall correctly, a small (and I do mean small) amount of spark is a good sign. It should also happen every time the points "open" if my logic is correct. If it doesn't, then it only makes sense that the circuit is open (i.e. fouling plug, bad wire, flaky coil, dirty/loose connection) so you may want to give those items a quick look-see.
If the spark is huge, I'd look at the condenser (capacitor in electro speak), I am pretty sure that it's job is to keep that spark to a minimum so as not to "burn" the face of the contacts (points). If the contacts are blackened then current won't flow freely through them and you won't see the small spark you expect to see.
Hope this helps!
Old Sep 2, 2006 | 02:00 PM
tedali2004's Avatar
tedali2004
Default RE: Points
The pionts and condesor are cheap and easy to change. This sounds like a bad condesor. You can buy them separately. Keep the pionts area clean and dry with the right gap.
Old Sep 2, 2006 | 02:34 PM
JAMES2's Avatar
JAMES2
Default RE: Points
Thanks for getting right to the POINT ! I'm gonna give it one more look for now, then convert to electronic anyway! Just hope'n to ride some more before winter!!!!!!!!!!
Old Sep 5, 2006 | 06:12 PM
JAMES2's Avatar
JAMES2
Default RE: Points
In regard to my question, it was a bad coil. It worked fine for 3-4 mins, seems when the coil heated up it caused the circiut to fail and killed the engine. Thanks for the help.
ORIGINAL: JAMES2
Any thoughts?
Old Sep 5, 2006 | 06:18 PM
pittguy's Avatar
pittguy
Default RE: Points
Always replace points and condenser at same time,Phenolic block on points wear rapidly w/higher speeds.Then Id start looking at coil,wiring.
Old Sep 6, 2006 | 01:40 PM
tedali2004's Avatar
tedali2004
Default RE: Points
ORIGINAL: pittguy
That's good advice, but I had a time where the new condensor went bad twice before I found one that would last. I hate being a parts changer.
Old Oct 25, 2024 | 12:24 PM
jones91's Avatar
jones91
Stage I
Default 1966 Harley Davidson
Hope this helps!
I’ve got a 1966 Harley Davidson new points new condenser, coil still don’t have a spark any suggestions would be greatly appreciated
Old Oct 25, 2024 | 01:30 PM
touchdown's Avatar
touchdown
Any thoughts?
coil
Old Oct 25, 2024 | 03:52 PM
DooWop's Avatar
DooWop
You need a meter. Don't be a parts changer. Your problem could be anything in the circuit even a loose wire. Fortunately it's a fairly small circuit.
You'll need a wiring schematic to save frustration.
mikeyhd is correct that the capacitor (condenser) is to reduce spark at the points when they open. In fact a bad cap will build
up the point material like a little pimple and is a good way to know if the cap is bad or you could test it if the meter has that feature.
Most don't but for few more $$ they do.
