points question
Old Dec 13, 2010 | 08:23 PM
98glider's Avatar
98glider
Default points question
I want to check my weights behind the point plate. Can I mark the plate before I take out and check the weights to make sure they work properlyand the springs are good. I am not familiar with the points yet and just want to make sure I don't mess anything up yet thanks
Old Dec 14, 2010 | 12:57 AM
shovel13's Avatar
shovel13
yep just mark the plate to the cover. if the weights look good clean them up and put some anti seize on the pins and while you're there replace or at least clean the points with a nail file or something like it.
Old Dec 14, 2010 | 09:03 AM
sqdealgeorge's Avatar
sqdealgeorge
Mark the center of the two studs that hold the plate in position so the timing will remain where it's at (slotted holes )
Old Dec 14, 2010 | 03:34 PM
98glider's Avatar
98glider
When I mark the plate and the sides of the timing cover, won't the timing still be okay. I would put the plate back into the same spot. Also what do I use to clean the weights and anti seize there is different types I just don't want to mess anything up Thanks
Old Dec 14, 2010 | 04:32 PM
sqdealgeorge
As long as the plate stays in the same position Good to go I grab the weights and see if there is alot of wobble on the pins If so replace the unit I use gray anti seize (permatex) on just the pins
Old Dec 14, 2010 | 07:44 PM
98glider's Avatar
98glider
I can just replace the weights and pins not the plate Thanks
Old Dec 15, 2010 | 08:35 AM
sqdealgeorge
No the plate has the pins (one piece) There are several diff plates out there Some systems have diff pin sizes The orig plate and weights is probably what you have The replacements are inexpensive I usually see the weight holes elongate not so much the pins wearing out However I have seen both weights/pins on one shovel trashed you can buy the whole system for say $45
Old Dec 15, 2010 | 03:51 PM
98glider's Avatar
98glider
so then if the weights and or pins are shot that means I have to change the plate and then adjust points and time again Thanks
Old Dec 15, 2010 | 05:16 PM
sqdealgeorge
Hey 98 if you need to re-time /set pts just let us or me know It's no big deal in fact quite easy We'll walk you thru it
Old Dec 15, 2010 | 05:31 PM
98glider's Avatar
98glider
Thanks I am goin in tommorrow I just need some knowledge before I start, the manual is confusing and sometimes it looks more difficult then it is Thanks again
varider12$
2014-2024 Touring Models
Apr 12, 2017 06:54 AM
DeneFXDWG
Jan 7, 2017 10:54 PM
Glen1978
Feb 28, 2012 04:03 AM
bkbob08
Dec 20, 2008 02:14 PM
Bluerose
Jul 6, 2007 08:16 PM
