Clutch lever going slack??
Old May 7, 2011 | 10:00 AM
cadillac6661's Avatar
cadillac6661
Default Clutch lever going slack??
Bought a new bike last week (my first Shovel a 75 FXE, finally!) All worked well then the clutch lever started getting slack and finally wouldn't engage the clutch. I adjusted the cable and it worked beautifully for roughly five miles and slowly went slack again.
Ideas?
Old May 7, 2011 | 01:24 PM
panz4ever's Avatar
panz4ever
I would pull the primary cover and disassemble the clutch pack, clean and inspect all components, including the clutch pushrod and throw out bearing. Replace obviously worn out parts. Put it back together per the manual and then test it again.
Make sure you do the adjustment with the bike cold.
If you have a question about whether the part is still serviceable, post up a pic. Beats trying to describe what you are looking at.
Congrats on the new ride. Can't beat old iron. How about a pic of the new bike?
Old May 7, 2011 | 01:49 PM
cadillac6661
Thanks for your reply! I love the old shovel already. I wouldn't have believed it of someone told but there's a wheelbarrow load difference in it and the ironheads I've had...
Old May 7, 2011 | 02:43 PM
TwiZted Biker's Avatar
TwiZted Biker
Like the man said probably the clutch pushrod adjusting screw , once they start to eat themselves it won't stay in adjustment very long . May time for a new heavy duty cable too avoid the cheaper ones if you can they stretch like crazy .
PS clean bike and looker too . Theres no comparison between this bike and sporties bro as your finding out .
Old May 12, 2011 | 01:59 PM
Krutch's Avatar
Krutch
From: somewhere in "The Peoples' Republic of Illinois
I suggest he replace the throwout bearing with the old type bearing OEM #37310-39 and 37285-38 pushrod. The wafer type bearing just is not up to the job.
Old May 12, 2011 | 04:07 PM
TwiZted Biker
That yr should still have the old style in it if I remember right .
Old May 20, 2011 | 06:48 PM
Krutch's Avatar
Krutch
Yes it should have an old style bearing, but we don't know this bikes' history. Something is making the throwout rod and adjuster screw eat each other, I think. If someone changed the OEM bearing with the 'wafer' type you could have such a result, eventually. Could be it was replaced by a HD shop when the OE part showed obsolete. Or part missplaced and replaced by what is available.
I am refitting my '78 FXE for my cousin and he has 'lost' many parts he should not have lost. This bike has cost much more to build due to this and some parts are no longer available. I am not one to 'throw' a bike together and making it as good as it was has been frustrating. I some times think he disassembled everything and threw it into a corner. Might as well as started with a basket case.
Really wish I hadn't sold this bike. It has been a good machine served me well.
Old Jun 1, 2011 | 09:02 AM
hobobiker's Avatar
hobobiker
Cadillac, if you get to the point of pulling the clutch plates I would do the following while you're in there:
1.) Clean the fibers and steels with brake cleaner, gas, kero, etc. to remove the gunk.
2.) Take your fiber plates to the nearest spot of flat concrete and "scuff" them by doing about ten or fifteen "figure 8s" on each side.
3.) Stack your steel plates on top of one another to ensure that they are flat. Seeing a lot of light in-between the plates will be a sign that they are warped from heat and need replaced. Might also want to check that the ball bearings are in the tips of the clips.
4.) Check the studs on your clutch hub. If they are worn with grooves, this can catch on your plates and not allow for smooth clutch movement. Fine-grit sandpaper or a scotch brite pad can smooth these out a bit. You can also drill the holes one size larger in your fiber plates which will allow for easier movement.
5.) If you see that the clutch hub nut is leaking through the center, the seals are cheap, easy to replace, and i sometimes run two of them (one on top of the other).
My .02
Hobo
Old Jun 1, 2011 | 04:55 PM
TwiZted Biker
Look at the adjusting screw in the pressure plate first , those like to eat themselves once in while . You'll adjust it and before the test ride is over you have slack and dragging clutch again . If that's it you have to change it and the throw out rod that goes through the tranny .
Old Sep 24, 2011 | 05:02 PM
cadillac6661
Sorry to bump this old topic buy I'm JUST NOW getting around to pulling it apart!?! If you guys could answer a few questions about these pictures I'd be grateful beyond words!!
1. The oil slinger means it's new wafer style right? Shouldn't the bearing be between these 2 washers? (came outta the tranny exactly add you see)
2. Can you tell if this cover will allow me to go back with the old style?
