make it simple
Old Mar 17, 2012 | 09:25 AM
rugg-i's Avatar
rugg-i
Stage I
Default make it simple
i,m trying to set valves in 80" shovel,read manual ,understood ,done it wrong ,can't seem to get my head around proceedure! can someone give me simple directions,with a logical starting point? thanks
Old Mar 17, 2012 | 10:40 AM
panz4ever's Avatar
panz4ever
Hydraulic or solids? Makes a difference
Hydraulics wet... pushrod at its lowest point on cam, loosen lock nut, add slop, then take out till you just have no slop then 4 full turns and lock it down. Wait for unit to bleed down (it will turn freely when it has) then move on to the next.
Hydraulics dry...pushrod at its lowest point on cam, loosen lock nut, add slop, then turn down (lengthen) until it bottoms out, then back up 1-1/2 turns and then lock it down. Wait for unit to bleed down (it will turn freely when it has) then move on to the next.
Hydraulics solids...pushrod at lowest point on cam, loosen lock nut, add slop, then take out slop to the point where you can spin the pushrod with two fingers, then lock it down and move on to the next.
Old Mar 17, 2012 | 11:38 AM
msgtarmor's Avatar
msgtarmor
This part is critical!!! I've seen bent valves because of someone getting impatient and not waiting. Could take several minutes for each one to bleed back down, especialy when the motor is cold...
jim
Old Mar 17, 2012 | 03:37 PM
panz4ever's Avatar
panz4ever
jim
One of the reason God created good old Tennessee whiskey!
Old Mar 17, 2012 | 04:37 PM
msgtarmor's Avatar
msgtarmor
I had to switch to beer cuz I was too drunk to finish by the time I got to the second cylinder!! I could never pace myself with whiskey. Within an hour I'm 10ft tall and bullet proof and usually let my alligator mouth override my hummingbird ***!!!
jim
crazytown
Engine Mechanical Topics
22
Apr 18, 2016 11:41 AM
danzio
Sep 19, 2011 11:27 AM
18BKLR
Nov 13, 2010 04:12 PM
RidemyEVO
Jan 31, 2010 07:29 PM
RangeRat
Oct 29, 2007 05:46 PM
