inner primary
Old May 6, 2012 | 09:28 PM
berndog's Avatar
berndog
Default inner primary
What the heck do you guys use to get out that Big screw holding in the solenoid lever,,it aint budfgin at all
Old May 7, 2012 | 09:23 AM
panz4ever's Avatar
panz4ever
Just a wide tip flathead screwdriver should do the trick. Thinking yours might have been a long time since it has been removed. Try using something like PB Blaster and letting it sit.
Old May 7, 2012 | 03:58 PM
berndog's Avatar
berndog
That PB blaster is awesome stuff,,I actually had to heat the **** outy of it
Old May 7, 2012 | 07:40 PM
TwiZted Biker's Avatar
TwiZted Biker
Take a 3/8 bolt and use it as a flat punch and smack the top of it a couple times then try again , you can also cut a flat on big washer and use a crescent wrench on them .
Old May 7, 2012 | 07:55 PM
AlCherry's Avatar
AlCherry
Am I the only sumbich left in this world who still uses the old hand impact?
Old May 7, 2012 | 08:01 PM
berndog's Avatar
berndog
Thats the first tool I tried Al,ended up heating it up,first,,and impact,,,do you guys have any knowledge on Karata belt drives? do I have to grind a little out of the inner primary at front? and what is the placement for the idler gear?
Old May 7, 2012 | 11:39 PM
msgtarmor's Avatar
msgtarmor
No Al, there's 2 of us old fossils that still use em!!
jim
Old May 8, 2012 | 01:46 AM
TwiZted Biker
Need a picture of your belt setup , BDL makes one with the idler not Karata . I've used them all just gotta see what you have to give the right setup unfo , they all have quirks .
The slot head stuff I've got 3 dif. sizes of the old drag link sockets , got tired of the of rigging things .
Old May 8, 2012 | 09:45 AM
berndog's Avatar
berndog
it is a karata belt drive the idler was bought separate,seems the front pulley guide is going to rub on the front mouting hole of inner primary
Old May 8, 2012 | 12:23 PM
TwiZted Biker
You just take a file to that , common . Shouldn't need an idler with the Karata , those go on the BDL 11mm systems as far as I know I'm running one of them now .
