FLH instrument panel question
Old Mar 11, 2013 | 11:16 PM
nervehead's Avatar
nervehead
3rd Gear
Default FLH instrument panel question
how do I get the damn thing off?
1978 FLH
Does it pry off, or unbolt? I'm lost.
Thanks for help.
Old Mar 12, 2013 | 07:03 AM
johnjzjz's Avatar
johnjzjz
not knowing if you have a stock dash cover the question with out a picture of what you have ??? is not helpfull in getting a good answer
Old Mar 12, 2013 | 03:07 PM
nervehead's Avatar
nervehead
3rd Gear
Exclamation
good point, I'm not where I can upload a photo, but I will.
But it is stock.
Old Mar 12, 2013 | 04:04 PM
panz4ever's Avatar
panz4ever
Stock instrument panel cover...there is a small nut below the choke lever that needs to be loosened. 1st take of the choke ****, then the nut. Then there is a nut that holds down the cover to the tankjs that comes off. On my 84 the panel comes off to the right and and then up in the same motion since the trip odometer is not datched from the speedo housing. On some models you need to remove te trip **** with a very small screwdriver and then the cover comes straight off.
FL54
Shovelhead
Mar 1, 2024 09:03 PM
mechmagcn
Shovelhead
18
Apr 12, 2021 02:11 AM
Joey Bruce
May 19, 2013 12:52 PM
Ironbarr
Mar 14, 2010 12:34 PM
bbsbase
May 20, 2008 05:49 AM
