That ONE thing....
Thanks
its great that you have your dads bike - enjoy it -- jz
A little attention to detail , do a proper repair when needed and not let little **** turn into big problems a shovel can give you a life time of riding . Most horror stories you hear about shovels are owner induced .
RULE# 1: Purchase and get familiar with a HD service manual and HD parts manual that coincides with the yr of your scooter.
The list below are some things to keep in mind.
For safety, always disconnect your battery when working on a mc.
When someone gives an answer to your question, double check using the service manual. (I'm a French model, bonjour)
Take your time, double check your work when working on your scooter.
When removing parts and not familiar with them, label all part, nuts and bolts, even take pictures if need be. Sure your gonna say, I'll remember that bolt goes there, but when you turn around to get a tool, chances are your gonna forget where it goes.
When repairing electrical, Disconnect the battery. Invest in a booklet of sticker letters and numbers. Label each end of the wire and connection where it goes.
A shovel can be a forgiving motor, but there are some "Oh *****" that over ride the forgiveness and can be costly.
I'm sure there's more tips that some one will chime in with.
Get a big folder and make note's , pictures and any instruction sheets for any aftermarket part you may use . It will be used again .
The biggest problem when someone buys a highly modified/custom scooter privately, they have no clue what parts are in it. That's when it get frustrating even just for the basic maintenance.
This goes for anyone viewing this thread. Whether an expert or just starting out on shovels. It has helped me out tremendously.
