A calm cough cruising between 50-55 mph. '66 Electra Glide
Old Apr 29, 2013 | 06:44 AM
team_c0ulter's Avatar
team_c0ulter
Stage II
Default A calm cough cruising between 50-55 mph. '66 Electra Glide
Carb has been rebuilt.
Intake seals, sealed.
Points are new and set properly.
Advance weights and springs, new.
Original Carb, original distributor, original intake.
Any ideas or thoughts?
I'm thinking the advance weight posts are wore out letting the weights flutter.
Old May 2, 2013 | 06:45 PM
johnjzjz's Avatar
johnjzjz
that carb has an adjustable main and low speed adjustments not replaceable jets like most
the top screw that faces the right handle bar end is low speed - if it idles just fine leave it alone if you do adjust it remember what you did so you can put it back
on the bowl the little rod that is bent 90* at the end is high speed only adjust it 1/8 of a turn at a time counterclockwise is richer i think you need to go richer
what happens is the low and high have a spot that one ends and the other starts soo its a feness thing -- hope that helps i seen question about this and thought i had answered it i guess i dident -- jz
Old May 2, 2013 | 06:51 PM
Stiggy's Avatar
Stiggy
Agree with johnjzjz, It's acting just a little lean. I would play with the low speed adjustment though, ( 2500 rpm - 55 mph ?) but as was said, don't forget where you started.
Good luck.
Old May 5, 2013 | 10:26 PM
team_c0ulter
Stage II
Default Thank you guys.
I haven't got a chance to look at it yet. But I will and I'll get back to you guys...
Thanks Again!
mikeawin
EVO
14
May 19, 2019 07:35 PM
89FLHTC
EVO
45
May 6, 2016 05:23 PM
superwoody2
EVO
May 8, 2014 02:45 AM
busterman2
EVO
Nov 13, 2012 09:18 PM
64Panhead
Exhaust System Topics
Feb 14, 2010 11:42 AM
