wide glide front end
Old May 31, 2013 | 08:40 AM
883drummer's Avatar
883drummer
Question wide glide front end
I have a supposed to be a 1980 wide glide front end with 41mm fork tubes but who knows cause i bought it at a swap meet... soo i took it apart to get the trees and lowers powder coated and now im putting it back togheter but i have run into an issue.... what is the best way to punch the oil seal back into it without messing it up??
Old May 31, 2013 | 09:27 AM
Uncle Larry's Avatar
Uncle Larry
Use a piece of scrap tubing or some PVC that's the correct size ... Be sure that the tubing is contacting the seal on the outer portion ( outer diameter ) of the seal so as not to damage the the inner ( sealing ) portion of the seal.
Old Jun 1, 2013 | 06:07 PM
TwiZted Biker's Avatar
TwiZted Biker
Yep 2" with a cap glued on one end about 18" long , rubber hammer too .
purplewg
Mar 9, 2018 12:39 PM
pheur
Nov 18, 2013 09:18 AM
2kChopper
Aug 27, 2010 01:53 PM
JoeBobber
Feb 26, 2010 10:06 PM
HDRIDER10
Oct 20, 2009 10:26 AM
