Breaker plate screws - hard to remove on my 1978 FXE
Old Jul 19, 2013 | 11:37 AM
toddlaroche's Avatar
toddlaroche
Unhappy Breaker plate screws - hard to remove on my 1978 FXE
I want to adjust the timing on my 1978 Harley FXE. When i tried unscrewing the breaker plate screws (at 9:00 and 3:00 oclock positions), i couldn't get them to move... These screws (or bolts) have a thread within them for the timer cover screws, and a flathead screwdriver indent at the top for their removal. Problem is, they're so tight, they won't move and the screwdriver notch is already starting to strip. Anyone ever encounter this issue? Is there a special tool or approach i can use to remove these screws so I can adjust the breaker plate?
Help!?
Old Jul 19, 2013 | 05:50 PM
megawatt's Avatar
megawatt
You could try a hand held impact with the flat screwdriver blade bit.
Squirt WD-40 or other penetrant type oil in the slots to get it in the threads of the hold down screws and let it soak in for a while.
Old Jul 19, 2013 | 07:55 PM
johnjzjz's Avatar
johnjzjz
be carfull with that the screw thread is 8 / 32 on the other end of the slotted post you are trying to turn
i would get a brass drift and give the post a knock dont hit it too hard just give it a shock --- than a very small vice grips you can snap them on the post BUT only turn it ever so small a turn than go the other way ever so small a turn maybe 20 thousands of an inch back and forth when it feels free add some movement but not before --
like the post above add WD 40 into the mix a few times they suck when they break and they do very easy -- take your time -- jz
Old Jul 19, 2013 | 11:07 PM
panz4ever's Avatar
panz4ever
PB Blaster is a great solvent for these types of tight threads.
Old Jul 20, 2013 | 07:15 AM
Joe12RK's Avatar
Joe12RK
+1 on PB! Kroil is even better if you can get it.
Old Jul 20, 2013 | 08:24 AM
johnjzjz's Avatar
johnjzjz
both are totally correct with PB and Kroll BUT / BUT i cant stand the smell of ether one so we make our own
marvel mystery oil and 100% pure acetone < girls nail polish remover ( ONLY ) not home depot stuff mix it 50 / 50
care around paint must be taken but it will do the job very well -- jz
Old Jul 20, 2013 | 11:29 AM
TwiZted Biker's Avatar
TwiZted Biker
Smooth man , may try that .
BergerGK
Mar 30, 2014 08:02 AM
glide_n_around
Oct 1, 2013 03:45 PM
toddlaroche
Jul 20, 2013 06:32 AM
big_e78
Aug 1, 2009 09:52 PM
street bob 59
Jun 26, 2009 02:03 PM
