Pistons
Old Sep 10, 2013 | 10:26 AM
cajun1957a's Avatar
cajun1957a
Default Pistons
Just got word back from the machine shop. I need standard intake valve guides, 2 over exhaust guides for the heads and 20 over for pistons. What is a good piston to use? Can I go 9:1 pistons without any head work? Keith Black, Weisco, jp cycle stock? I will go what the consensus says.
thanks
randy
Old Sep 10, 2013 | 11:42 AM
biginchhustler's Avatar
biginchhustler
and the engine is? 74" or 80"? 9:1 with single plug heads will ping its *** off - -- dual plug the heads -- have the squish band set --
or this for a 74" -- http://www.ebay.com/itm/ENGINE-PISTO...ab6895&vxp=mtr -
for an 80" but 8:1 same brand
Old Sep 10, 2013 | 10:45 PM
i Confederate i's Avatar
i Confederate i
Viola v twin pistons. Been running them in my 75 FXE. Never had a problem. Super light weight compared to the stock pistons, and incredibly strong.
Old Sep 11, 2013 | 07:41 AM
johnjzjz's Avatar
johnjzjz
Venolia pistons are forged need more room in the cylinders than the cast stock pistons ( They are noisy hot ) and YES they are lighter and so are the tool steel pins they come with - we always found we had to re balance the motor to use them 10 grams changes the balance factor by 1 and they are lighter than 10 grams as compaired to a stock piston
2 things i have not seen them in the new book from V twin
and BIH is right on with his answer Plus 1 for me as well
Old Sep 11, 2013 | 08:03 AM
biginchhustler
exactly what john says-- don't be mislead into fashion parts -- lighter my be a good thing but without re-balance your gonna shake your teeth lose..
the ones I listed are stock like weight and cast for long life -- im going on 5 years and untold miles on a set in my 80"
the coating on them is only for brake in it wears off -- check automotive pistons like speed pro they use the same coatings -- I wouldn't use the rings I would get total seal rings to go with the pistons..
email this guy --- keithj@totalseal.com tell him the brand of piston and use the total seal -- hey IMO
Old Sep 11, 2013 | 09:35 AM
biginchhustler
-- http://www.totalseal.com/PartDetails...om=Application --
traveler
Exhaust System Topics
Mar 25, 2020 10:04 PM
treeratt59
Shovelhead
21
Dec 9, 2018 04:06 PM
Rusty Axle
Shovelhead
Nov 30, 2017 04:01 PM
Hillsidecycle.com
Engine Mechanical Topics
11
Dec 15, 2016 09:52 AM
Tltrump
Nov 5, 2006 03:28 AM
