Tempermental running
Old Oct 9, 2013 | 02:47 PM
Major94's Avatar
Major94
Default Tempermental running
Ok, she runs fine most of the time. Yesterday at 5pm and today at 1pm, it starts smoking white smoke when i am at idle. Then after that we get a nice little misfire going on. It came out of it after about 3 minutes yesterday, today I drove it 5 miles back home and never stopped misfiring, I put it on the charger hoping its a battery issue on the misfire.
White smoke?
Old Oct 9, 2013 | 05:23 PM
johnjzjz's Avatar
johnjzjz
it could be a bad plug it could be a bad wire < you have not posted if its a single fire so dont know if the coil is suspect --
thats the easy stuff -- you need to do a conmpression test and if you have a leak down test to determin the engines condition - low compression can and does do just that, and that could be a bunch of things, you need to check it before an answer can be given correctly - johnjzjz
Old Oct 11, 2013 | 05:48 AM
Major94's Avatar
Major94
So I did a compression test.
Front cylinder had 60psi
rear cylinder had 110psi
Im no expert, but im thinking the fron cylinder has some sort of problem.
So, I pull the head and jug off, and the cylinder walls look like dog crap. There are more scratches on the walls of that than I have ever seen.
New plan. Either have my engine bored over and get new cylinder, or buy the S&S stroker kit. I already have a Delkron block, so I can make it work.
What do you guys think?
Old Oct 11, 2013 | 08:00 AM
johnjzjz's Avatar
johnjzjz
if you end up with te stroker idea go low compression 8 to1 -- if you want it to last with the $hit gas we now have -
Sure some one runs 11 1/2 to one 120 inch shovel kick only -
but in the real world you have to be able to use it any time you want - i always liked the 86 if its a 1200 or the 89 if its an 80 inch combo - they make great power and last like a stock motor if taken care of - just my take - johnjzjz
Z
Engine Mechanical Topics
50
Sep 16, 2018 11:11 PM
Ironyman
Ironhead
11
Oct 23, 2014 07:43 AM
rkingstp77
Nov 19, 2013 05:58 PM
bubba 40
Shovelhead
Feb 26, 2010 05:55 PM
1200c
Exhaust System Topics
Sep 22, 2005 07:00 PM
