No compression
Old Dec 2, 2019 | 11:34 AM
Hairysraiders's Avatar
Hairysraiders
Stage II
I had the same problem on my 1984 FXE shovel. It ran well in the summer but sat a couple months into the fall, no compression. I heated the tappet blocks with a heat gun till good and warm, then tried kicking - wa la compression.. Turned the gas on and hit the button it started and ran like before. I'm guessing the oil was cold and thick and the valve spring pressure wasn't enough to push the lifters down quick enough.
Old Dec 2, 2019 | 05:51 PM
TommyShovels's Avatar
TommyShovels
This thread makes no sense..
loosen your pushrods to the point they want to fall out then do a compression test. 0psi-5psi? that's a LOT of lost compression, you should be hearing it come from somewhere..
blown head gasket, bent valve.. idk, do some playing and get back to us.
Old Dec 7, 2019 | 11:04 AM
1981 suprglide's Avatar
1981 suprglide
wow you have to wait until the engine is cold all the push rods bleed down then put the proper torque on them
Old Dec 7, 2019 | 11:44 AM
Hoginedgewood's Avatar
Hoginedgewood
Id suggest adjusting the valves. Id guess the dipstick issue is from sumping, I wouldn't worry about that yet. First id get the compression to where it will run.
fergerburger
Shovelhead
14
Oct 4, 2017 10:47 AM
greggmig
Engine Mechanical Topics
27
Jul 5, 2016 10:03 AM
jh2pizza
Apr 16, 2011 12:07 PM
GARY CROSSLEY
General Topics/Tech Tips
Feb 21, 2011 10:08 AM
gunteach
Shovelhead
Jul 29, 2007 09:48 AM
