Eff'n Battery Connections
Old Aug 5, 2019 | 03:43 PM
John CC's Avatar
John CC
The Duracell batteries are made by Deka.
When I re-torque, the bolts don't even move a noticeable amount, but works every time.
This would lead me to believe you have some sort of conductivity (corrosion) issue rather than loose connections. Split washers help with both. Dielectric grease helps preserve conductivity. I don't know if I'd use Loctite. It'll keep them tight, but many batteries are ruined by twisting the terminals. (1,000,000 ft-lbs isn't going to help them either...)
Old Aug 5, 2019 | 04:06 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by Clayjenson
+1
Check for the brass spacers.
Wasn't any on my bike when I got it so I didn't know. It made the connections not flat. Melted the lead posts.
The spacers are not needed as your battery cables run along the side corners and sit flat on the battery terminals. Melted leads = loose connection.
Old Aug 5, 2019 | 05:22 PM
im's Avatar
im
It is possible that i missed year and exact model.
But it would appear to be a dyna.
The aftermarket batteries have posts that are set back from the battery edge.
The spacers shown in pictures help to line-up the cables flat against posts.
Many folks toss them when buying a new aftermarket battery but they should be used.
The running of wire to battery can also loosen cable if it is runs in a manner that permits vibration to twist cable left/loose.
If cables are loose and not making contact then heat can result at posts and cause damage to battery or charging system.
Old Aug 5, 2019 | 06:12 PM
Mid-Night-Rider's Avatar
Mid-Night-Rider
You didn't miss it, I neglected to provide such info. 2009 Street Bob.
When I get home (leaving work now) I'll take all the connections apart and go over the entire thing in detail. Clean, reassemble using split washers if not already equipped, see if spacers would help/needed maybe add them anyway, little bit of lock tight, and some electric grease.
Just going to throw everything at it as I'm really over it.
Thanks everyone for the constructive feedback. Much appreciated!
Old Aug 5, 2019 | 08:27 PM
John CC's Avatar
John CC
If you have to buy hardware, get stainless.
Old Aug 5, 2019 | 09:47 PM
crusader1xxx's Avatar
crusader1xxx
The other thing I just did to both of my bikes...was cover the terminals with electrical tape...not sure if it will help, just thought the tape might hold it in place...honestly I did more as a precaution against any potential arcing against the cover...
Old Aug 6, 2019 | 03:41 PM
F86's Avatar
F86
Ha, I've done that too! I'm always scared about accidentally grounding the positive side... It's really close to the frame!
Old Aug 7, 2019 | 11:25 AM
hdbob2006's Avatar
hdbob2006
Also make sure the battery is held down snugly,so it can't move around. I had a softail that the cables kept coming loose,and I had to put a few pieces of foam backed carpet in front or behind the battery to help secure it.
Batteries bouncing around with nothing but a rubber strap to hold them is not good.
Old Aug 7, 2019 | 04:23 PM
dyna rider's Avatar
dyna rider
Default Battery Terminal Screws
As already said, use internal lock washers and blue locktite. My dyna shakes a lot and will eventually make the screws loose in the terminals. On the original battery, I finally safety wired the screws so they couldn't come loose. Since you can't safety wire them together, I drilled a small hole in the very corner of the battery case on each side of the front and then safety wired them to that hole. I didn't drill it into any "meat" of the battery, just a nick on the corner. I used 28 thousandths wire and never had a problem again. I've been through several batteries since then but never had that problem reoccur.
The electrical leads should come at the battery from the side, like the WS6 Formula pics. If it is done like that, you won't need the spacers and that looks like where the problem originates.
Old Aug 7, 2019 | 09:23 PM
straydog13's Avatar
straydog13
I always cover the battery with a piece of inner tube. I cut slits into a piece of tube and run the cables thru it . Is it needed...I dunno...makes me feel better. I guess it's possible to be a problem if any gas couldn't escape if a battery had issues but that's not the case.
And agree completely with using spacers if needed. . Or putting on side etc. Whatever u gotta do. I dunno why but on many many things people drop the ball attaching terminals. ..bikes...cars..four wheelers... tractors.
wardjs
Jul 7, 2019 03:52 PM
kopp
Mar 25, 2010 01:40 PM
maineultraclassic
Mar 16, 2008 10:28 AM
04RoadKing
Apr 22, 2007 06:29 PM
wlbowers
Dec 15, 2006 10:15 PM
