Oil Filter Comparisons??
Not sure i believe any filter goes to 5 microns although its possible.
Everybody says a Sporty wont oil with a 5 micron filter ? Prove it !
Most filters that fit a Sporty are about 20 micron
The Harley 5 micron filter appears to be built by Purolator with media made by Donaldson
The Amsoil synthetic filter appears to use the same media but is made by Wix.
If you showed me just the guts of 20 filters i believe i could tell you who built the filter with 95 % accuracy.
A micron rating is given to show the efficiency of the oil filter (one micron is a millionth of a meter).
This leads consumers to believe that the 10 micron filter must be better for their bike. Here is where it can get confusing though. The 10 micron filter may have a higher filtration rating it does not allow the oil to return to the tank as fast. With this in mind, the 10 micron and the later (newer) 5 micron filter filter was developed for use with the Twin Cam style engine which has a different oiling system that allows oil to be forced through a more restrictive oil filter.
The reason for the tighter filtration was explained by the manufacture as necessary to assure all of the smaller passages in the Twin Cam style engine like the piston oil jets, would stay clear of debris. If you run the 10 micron filter with an evolution style engine it will not be able to return oil through the filter fast enough causing the oil to back up into the lower end (sumping) robbing power and/or causing oil to puke out of the lower end and into the air filter housing.
The 30 micron filter is designed to work best for your Evolution style engine, the filtration is still excellent and it will not cause oiling issues.
When it comes to filtering oil, application is very important. There have been a lot of changes and updates to many filters on the market, with claims of better filtration, don't be fooled into using a filter that might not be the best for your bike.
The difference between the TC engine and the Evo engine oiling system is one is high pressure low volume and the other is low pressure high volume, thus the reason for the 10+ micron filters on the older engines.
"Why are Stainless Steel Filters better?
Click here to watch this
youtube video
to learn all the details."
Dyna Evo 91-98, Dyna Twin Cam 99-10
Softail Evo 84-99, Softail Twin Cam 00-11
Sportster 85-11
Touring Evo 82-98, Touring Twin Cam 99-11
Polished or Black Anodized Billet Aluminum Housing
Cleanable and Reusable
Superior Filtration 35 microns!
Proven Aerospace, NASCAR, Indy and Formula 1 Technology
High Flow Rate
Easy Filter Element Inspection
Unaffected by Water, Heat or Pressure
Environmentally Friendly
Pays for itself
Available Options: color: Black Anodized Polished Aluminum
Quantity: No, I am not at all affiliated with any brand, but I love my oil filter.
