Which cam for torquey 80 EVO ?
my ride is a 1995 Dyna Superglide Sport with a (so far) absolutely virgin 80cu.in motor.
Never been upgraded, ever. Virgin, you could say.
I have decided to do a few upgrades, namely air filter, carb and exhaust,
and a new performance camshaft... which is where I'm stumped.
Information overload.
Andrews ? 27...36...46...
Crane Fireball ?
Screaming Eagle ? I have found no fewer than FIVE SE performance cams... SE1, 3, 4, 11, 57...
So... considering I use my bike for daily commuting and weekend trips (and maybe one day long range solo riding) which cam profile would you suggest ?
I am after a torquey cam at low-medium revs, I have no need for a "screamin', hollerin', redline cam"
PS, My 2 cents; I'm still using the Modified CV Carb, if I was to get a New Carb, it would be a Mikuni 42, Bolt on 5 to 10 HP ! I also use 4 prong platinum tip, Bosch 4478, awesome spark plugs, like putting cams in ! Good Luck, Boston Jim
In the Andrews line, the EV27 is pretty much the 'go to' cam for an EVO. However, the power doesn't really start to come on until 'around' 2500 rpms. It works best with a better set of pipes, upgraded CV carb/air cleaner, and aftermarket ignition. I have been running an EV27 in my FLHS (ElectraGlide Sport) since 1994. It was a MAJOR improvement in performance on a very anemic bike.
If you want just an improvement, the EV13 is a decent cam. Much better than the stock cam.
There are a number of cams for the EVO, from a number of reputable cam grinders. So you really need to do a lot of homework to find the right one for your riding style, your roads, and your pocket book. But, in my opinion, most are better than the stock Harley cam.
Andrews EV-13 cam $119.95
Dynojet Thunderslide with Jet Kit 8708 $128.42
Crane Cams Time Saver Adjustable Push Rods 4-0030 $126.72
Dynatek 2000P DD2000-HD2EP ignition module $145
Crane Cams big axle lifters 3-2050. set of four for $189.95
Crane Cams cam bearing 7-0400 $15.51
Cometic Cam Gasket Service Kit C9624F $19.04
Cometic EST Top End Gasket Kit w/.030" Head Gasket $87.39
Screaming Eagle Air Cleaner Kit (Carbureted Evo) 295433-99B $127.96
New set of stock rings
Milled Heads .025"
What's the difference between an Andrews EV23 and an EV27 ?
Perhaps EV23 has a rounder lobe grind than an EV27 ?
http://www.andrewsproducts.com/sites...014-page13.pdf
When I was agonizing over the numerous choices I spent a lot of time here
http://www.nightrider.com/biketech/camdb.htm
as well as followed the various links on that page.
