2018 ultra limited water pump failure and replacement
The pierburg made pump from HD p/n 2600048 is what was on my bike. It is basically the same pump that is on the Audi and Porsche but with 12mm hose connections rather than the 20mm connections that are standard on the cars. The only other solutions I found online (other than an OEM water pump) involved hose adapting from 20mm to 12mm and I didnt want to do that do to the space available on the front of the bike.
so here is what I did: I ordered a pump from Amazon for an Audi $100. Swapped the impeller cover (this cover is where the hose connections are) and the rubber mounting ring for pump. Installed the new pump on the bike (with the impeller cover and rubber mount from old pump) and its working great.
attaching pics to show the parts.
Hope it helps someone else.
New pump installed
Impeller measurement
Cover measurement
Old impeller
Old impeller
Old pump cover measurement
Old pump left. New pump right
Failed pump. Motor locked up. I couldnt spin the impeller at all when I removed the cover
yes same plug and control.
This is a variable speed pump. There is no thermostat on 2018 and up. The three pin arrangement is 12vdc/Variable speed signal/ground. The ecm supplies the middle pin voltage (speed) to the pump. So when the temp sensor sends the temp signal to the ecm and then the ecm sends the voltage out to the middle pin and sets the speed of the pump.
on the 14-17 twin cam water cooled the pump is a two pin configuration so if you convert that to this style pump you will need to use an adapter cable to change this three pin to match the two pin harness on the twin cam.
@newbury2000 Can you post a link to the Amazon Audi pump or part number for future reference? Thanks.
I expect Rounders will be along to tell you about his water pump replacement in detail on his fictitious motorcycle.
just search for this
Electric Auxiliary Water Pump Coolant Pump 8K0965567 8k0965569 Fits for A4 S4 A5 S5 A6 A7 A8 Q7 Cayenne Panamera 3.0L Repalce OE 8K0965567 8K0-965-567
there are a number of suppliers. I used the one that had overnight delivery.The Best of Harley-Davidson for Lifelong Riders
But 2018, is the improved one??
What I would do different if I have time, was a longer bolt for the band that holds it in place to make it easier to get on and off. Though I can't tell if this one is same.
Amazon link should anyone need to search for it in the future:
