Electric starter
Old Yesterday | 01:44 PM
Spat's Avatar
Spat
5th Gear
Default Electric starter
Original starter is old and tired armature wobbles and worn bearing and bushing shot needs a complete rebuild most parts are available except I cannot find the brass bushing in the one end it probably an off the shelf bushing., It's such a PIA to get to and for the sake of reliability I'll buy new one. Rebuild my original if for no other reason just to keep the case with the Harley Davidson stamp on it. Did that with my generator a long time ago.
Drag Specialties advertises an OEM high torque replacement, same cost as standard starter. In another post I questioned an AGM battery and going that route and engine compression is around 9:1,
Anyone running one of these? battery or bat cables need upgrade for the high torque option?
Drag Specialties Black High Torque Starter for Models Equipped w/Prestolite Starters
  • Feature 15% more power and torque than OEM units
  • Manufactured using heavy-duty armature commutators, large drive-end bearings and needle bearings in the com-end caps
Old Today | 12:05 PM
t150vej's Avatar
t150vej
Don't fall for that "high torque" claim unless you just want bragging rights on how much you spent.
Buy a cheap one off amazon for about $125. I did about 60k miles ago, still turns it well. I'm not one to cheap out, but what works , works.
Just check the end bolts. A 1/4" is a Prestolite. A 5/16" is a Hitachi and the end gear is different.
Old Today | 02:53 PM
Spat's Avatar
Spat
5th Gear
I'm with you on the hype, didn't give amazon a thought. thanks
Ashilino
Sep 21, 2021 09:17 AM
tbeckstead11
Jul 17, 2020 06:56 AM
falconbrother
EVO
14
Jan 29, 2014 06:09 AM
kpb46
Oct 24, 2012 01:47 AM
dochawken
Sep 27, 2011 08:55 AM
