front ss brake line
Old May 14, 2026 | 03:11 PM
greyhorse's Avatar
greyhorse
Default front ss brake line
I’m going to replace the stock front brake line on my 16" ape Fat Boy. For sizing, should I get a +8" or +10" line? I’m curious, braided steel lines probably don’t follow the same routing as OEM, right? The OEM line is longer and loops over the fender before going to the left-side caliper. Should the braided line instead run directly down to the left caliper?
Old May 14, 2026 | 05:05 PM
1TxBiker's Avatar
1TxBiker
I'm running Magnum Shielding front & rear brake lines. They mount just like OEM.
Old May 15, 2026 | 12:34 PM
greyhorse's Avatar
greyhorse
With roughly 14” bars and stock risers, would a Drag Specialties +8” brake line be enough if I route it along the OEM path?
Old Today | 08:27 AM
1TxBiker's Avatar
1TxBiker
I answered about the brake line routing. As far as the length, ya might wanna use a tape measure to figure it out.
Old Today | 03:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Get a couple of feet of silicone or nylon tubing and route it correctly, mark it and measure.
FYI: 3/16" Silicone tubing is the stuff to use when bleeding brakes, it will fit snug onto the bleeder nipple.
RLC425
Jul 31, 2021 11:57 AM
Jman245
Sportster Parts
Jan 17, 2020 05:38 PM
LN2_Casey
Harley-Davidson Street
May 18, 2018 01:08 PM
jbone14
Apr 10, 2014 02:57 PM
Plow64
EVO
Aug 13, 2011 10:24 AM
