Fuel Guage and Left Turn Signal Indicator not working
Old May 16, 2026 | 12:34 PM
dmw8008's Avatar
dmw8008
2nd Gear
Default Fuel Guage and Left Turn Signal Indicator not working
I have a 2014 Street Glide Special that seems to have an electrical problem. The far left module houses the fuel gauge and the left turn signal arrow. Both have stopped working, however the left turn signals are working correctly, it's just the indicator lamp that isn't working. I figured that it was a ground issue but haven't been able to identify. I've checked all the fuses and they are not blown and are seated properly. Any suggestions? There are 3 wires going into the connector, one is hot when the switch ignition switch is on. Thanks
Old May 16, 2026 | 01:19 PM
GalvTexGuy's Avatar
GalvTexGuy
Started all of a sudden out of the clear blue?
Old May 16, 2026 | 01:43 PM
dmw8008's Avatar
dmw8008
2nd Gear
Yes, both the turn signal indicator (arrow flashing off and on) and the fuel gauge were working fine yesterday.
Old May 16, 2026 | 03:39 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
I would start by pulling the fairing off and looking at all the connections especially the one to the gauge cluster.
Old May 16, 2026 | 05:44 PM
dmw8008's Avatar
dmw8008
2nd Gear
Thanks! That was the first thing I tried. There are 3 wires that go to the gauge. I have 12v on the red wire when I turn the switch on. I figure the other 2 wires are "ground" that is switch somewhere but I can't figure out the wiring diagram. I appreciate you reply and any help!!!! Thanks, Marty
Old May 16, 2026 | 05:46 PM
dmw8008's Avatar
dmw8008
2nd Gear
When you mention the gauge cluster, I assumed you meant the one that goes to the affected gauge but you could be talking about another cluster. I'll keep looking.
Old May 17, 2026 | 04:17 AM
kojak's Avatar
kojak
Check the pins in the connector to the left side of the cluster aren’t bent or corroded.
Old May 17, 2026 | 06:05 AM
dmw8008's Avatar
dmw8008
2nd Gear
Thank you, I removed the small wiring harness, all pins appear to be straight and there is no corrosion that I can see. I could spray some contact cleaner in there and will try that. I've also wiggled it with the switch on to see if there may be a loose connection but couldn't find anything. Could the gauge simply be bad? I didn't know if that would stop both the turn signal indicator and the fuel gauge to quit working of if they are two separate items. Thanks for helping..
Old May 17, 2026 | 06:30 AM
kojak's Avatar
kojak
Use a multimeter, a wire can break inside the connector even if it appears good.
Do this:
  1. Backprobe connector
  2. Confirm:
    • 12V power
    • good ground
  3. Add temporary external ground jumper
  4. Spray contact cleaner
  5. Re-test
If still dead:
  • replace the fuel gauge assembly/module.
Old May 17, 2026 | 06:53 AM
dmw8008's Avatar
dmw8008
2nd Gear
  2. Confirm:
    • 12V power Good 12.8 v to ground
    • good ground
  3. Add temporary external ground jumper Added temporary ground jumper, still not working.
  4. Spray contact cleaner Sprayed contact cleaner, still not working.
  5. Re-test
If still dead:
I wonder if I can trust ebay dealers or should order from Harley???? And then figure out how to disassemble so I can take the lower screw out that is covered by the radio brackets lol. Thanks for your help, I'll let you know.
