To fill or not to fill is the question...
Stock shovel oil system is byzantine nightmare, started life as a total loss system due to the chain oilers. the crank vent line ported into the primary along with a dedicated feed off the pump to spray the primary chain. Primary was designed to run in a vacuum with all the metal shavings clutch plate fibers and other fun stuff flying around inside there getting sucked directly back into the cam chest through crack breather port , look in the breathe hole if you have a chance you'll see the port back in there, all the crap from the primary that didn't stay in the breather got sprayed all over the lifters , cam and sucked into the oil pump to be pushed to the in tank filter, half of which were bypassings or owners left them out.
This is why the bigger majority of owners went sealed primary like the later bikes, fewer lines & fittings, less leaks and cut of the crud going through th motors.
Want an education, if it hasn't been don't since you owned the bike, next time the oil tanks empty take a long screw driver and dig around the bottom of the the tank inside around the feed line port, see what comes out.
This way, the filtered oil would travel back to the sump to be pumped again.
