Cleaning ‘45 gas tank
Old May 21, 2026 | 05:20 PM
Oko's Avatar
Oko
Default Cleaning ‘45 gas tank
So I finally took the 45 out for a test run after it sat all winter. With Non ethenol gas I might add. And it ran rough at speed almost no throttle response wants to bog. So I figured maybe the gas was bad. So I siphon out all the old gas and I see crud in the bottom of the tank. And mind you it’s not a rotted out rust bucket of a tank. I don’t think it’s oem tank but I have no way of knowing.
Any ideas on how to approach getting the crud out?
Old Yesterday | 06:37 AM
Architect's Avatar
Architect
Fuel tank on a 45 is pretty ease to remove form the frame. Remove fuel line at shut off, three bolts and off she comes, leave the oil tank on. Then rinse as desired. For debris I would just rinse with gasoline, or maybe kerosene if available. If stuck on crud, white vinegar will get it done with some time.
Do you run a fuel filter? That can get crudded up, cleaning that out is part of my yearly maintenance. Good luck.
IronAss
Aug 19, 2022 03:55 PM
Curated Content Editor
Apr 10, 2017 03:22 PM
ylwf3vr
Dec 13, 2015 11:50 AM
Barky48
Mar 10, 2012 09:43 AM
cacasal
May 4, 2011 11:11 AM
