Where might this be from..??
Old May 23, 2026 | 02:34 PM
guido4198's Avatar
guido4198
Default Where might this be from..??
I pulled my primary cover this morning and found this very slender spring adhering to the magnetic tip of the primary drain plug.
Anyone have an idea where it might have come from..?
So far, I’ve pulled the compensator sprocket/chain/ clutch as a “ unit”, no idea from there.
Thanks.
Old May 23, 2026 | 02:53 PM
marcodarq's Avatar
marcodarq
automatic chain tensioner.
m
Old May 23, 2026 | 02:54 PM
MURPHCC1's Avatar
MURPHCC1
My guess is the oil seal at the Inner Primary Bearing.
Old May 23, 2026 | 03:18 PM
Schex's Avatar
Schex
If your bike is old enough to have a seal for the starter jackshaft, the spring from it would be my guess, but it would of had to been dislodged on assembly.
Old May 23, 2026 | 05:12 PM
guido4198's Avatar
guido4198
Sorry for the incomplete entry.
The bike is a 1985 FXRS.
Old May 23, 2026 | 05:19 PM
Jackie Paper's Avatar
Jackie Paper
Oil seal lip garder spring tensioner.
As long as it's not leaking, would not concer me. Eventually, as the lip seal wears a groove deeper, it will start to wick past the seal. (Soft laps hard)
Just monitor it.
Now if you planned a cross country trip, replace all the seals and cover gaskets.
Not a Harley but to help post make sense.
If its grooved, try to seat seal in a slightly different position if possible..
There are a lot of different size shaft saver SS sleeves. Not sure if there is an application for your bike.
Old May 24, 2026 | 07:01 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Them sprocket shaft seal on an 85 FXR Evo faces inward so I doubt it's the spring for that seal.. I would be checking the trans shaft seal on the inner primary..
Fatboyguy89
Jun 28, 2025 11:05 PM
0maha
EVO
52
Jun 19, 2016 08:31 PM
HDF Tech
Feb 26, 2013 11:14 AM
dawg
Mar 18, 2008 06:39 PM
RoadKingon
Oil Archive (no new posts)
Apr 25, 2007 10:42 AM
