External TPMS Amazon systems
Old May 26, 2026 | 11:31 AM
erh007's Avatar
erh007
Default External TPMS Amazon systems
Yes, external (cap-style) TPMS sensors can damage standard rubber valve stems. While the sensors only weigh about 9–10 grams, the rapid rotation of the motorcycle wheel creates centrifugal force, which applies significant stress and causes the rubber stem to bend and wobble. [[url=https://www.facebook.com/groups/roadtreking/posts/3319336961558593/]1, 2, 3]
The combination of the sensor's added weight and centrifugal force places specific strain on different valve stem types:
1. Rubber Valve Stems
  • The Risk: Standard rubber snap-in stems are not designed to support extra weight. At highway speeds, the spinning force can multiply the sensor's weight by up to 10 to 15 times. This constant flexing and bending fatigues the rubber base, leading to cracks, rapid air loss, or even a sudden blowout.
  • The Fix: If you want to use cap-style TPMS sensors, you must replace your rubber valve stems with rigid metal stems
I got a 2018 SG.
Old May 26, 2026 | 12:56 PM
NorthWestern's Avatar
NorthWestern
Cool story!
Nor sure what you are getting at here, but you can always just upgrade to the actual Harley TPMS system, and never worry about it again. Your Boom 6.5 will display the TPMS screen just fine.
Old May 26, 2026 | 03:29 PM
Leimy's Avatar
Leimy
I have 90 degree metal value stems. I just added the screw on TPMS. My 2017 doesn't have the built in feature. For $40, I can see psi and temp on mu phone. I can add to my other cars or bikes that don't have TPMS.
Old May 26, 2026 | 05:30 PM
2017M8's Avatar
2017M8
I tried a pair years a go and the rear tire cap actually cracked and the tire let go coming out of an round - A - bout,,,,yes the do flex. I believe mine hit the caliper housing over the length of the ride.
Old May 26, 2026 | 09:29 PM
Sandwiz's Avatar
Sandwiz
The T valve is the only way to go for the Valve top type,
have tried both single stem and the T valve, BELEIVE ME if you go with a valve top TPMS like the FOBO Bike 2 (which is what I have)
Then spend the extra and get the metal T Valves
FOBO Bike 2 T-Valve - 1pc (21P-TM-VAL0012/R1) (2ea)
AND Don't trust you life to the rubber valves stems to save a few bucks!
it's just not worth it.
Old May 27, 2026 | 06:12 AM
Jackie Paper's Avatar
Jackie Paper
Gee, read about them on here few months ago. Added them to the Tacoma 4X4. Just a round town vehicle for the summer mostly now. $30 dollars. Shows the pressure, temperature and alarm when they drop more than 3 lbs.
I don't drive on the interstate. So probably max is 45 -50 mph or so.
Interestingly, the Subie has then OEM but does give pressure or which tire.
The FIT has the latest direct reading type . It uses the speed sensors to warn you. No sensors or batteries in wheel. Didn't even realize it till I was replacing two wheels that were damaged.
Not sure how that works all that well. It has a calibration mode. Guess you use that just in case the rear to front are different. You really don't want two different tires on the front drive wheels.
Costco tires on vehicles. There safety consistent. Going to ask there thoughts on the Toyota. Now that's for 50mph...not 80.
Old May 27, 2026 | 06:37 AM
cdttzap's Avatar
cdttzap
I've considered them but with experience from adding just short stem extenders on a truck I had before, I don't think it's a good idea. I did add 90 degree stems recently along with a mark on the rotor as to where they are, making it easier to find. Just a small sharpie mark that will wipe off easy, nothing permanent. A while lot easier to find then the stem.
Old May 27, 2026 | 08:10 AM
cdttzap's Avatar
cdttzap
This might be something I'd consider. It's not a cap and seems reasonable
Amazon Amazon
Old May 27, 2026 | 11:34 AM
Sandwiz's Avatar
Sandwiz
https://www.amazon.com/Sykik-SRTP400...77&sr=8-4&th=1
Internal sensors are cool at least until its time to change the battery in them and or replace them because it went bad. now you have to unmount the tire from the wheel
With the external that is not an issue.
Old May 27, 2026 | 11:38 AM
cdttzap's Avatar
cdttzap
That's the version i was looking at. No caps to jack up
