Where’s the Data Link Connector?
Old May 27, 2026 | 06:25 PM
HoosierWagon's Avatar
HoosierWagon
Default Where’s the Data Link Connector?
A car fanatic is going to help me with a tuner. He obviously doesn’t know where the plug is, so I went looking for it. I’ve found several descriptions online and on YouTube. They all say the same thing: “under the left side panel, might be tucked behind the tubing, gray with a red cap.”
Well, there’s a lot of stuff in there, but no gray plug at all, with or without a cap.
Where is it, really? Could I trouble someone for a photo? It’s a 2021 Iron 1200.
Old May 27, 2026 | 06:43 PM
HoosierWagon
Hold on. Is this it?
Gray plug with a cap on it.
Old May 27, 2026 | 06:48 PM
John Harper's Avatar
John Harper
It looks like the plug just below is only attached with a plastic lanyard, so you may have found it. H-D probably saved millions not having to buy a special orange cap.
John
Old May 27, 2026 | 07:04 PM
HoosierWagon
Yeah. That cap was on the plug. I pulled it off to count the pins. So it appears I’ve found a capped, 6-pin plug. That pretty much has to be the DLC, right?
Old May 27, 2026 | 07:40 PM
John Harper
You can always check your wiring diagram on the HD service portal and check the wire colors to be sure, but I assume that's it.
https://serviceinfo.harley-davidson.com/login
John
Old May 28, 2026 | 03:25 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
That is the data link connector. When you are finished, if you look you will see a dovetail slot that the plug slides onto.
Old May 28, 2026 | 04:33 PM
Rounders's Avatar
Rounders
Manual has a page that lists the locations of the connectors with the numbers used on drawings for my bike. I've started to sharpie the numbers on them
Old May 28, 2026 | 06:04 PM
MURPHCC1's Avatar
MURPHCC1
You didn't answer the mans question, just what YOU do, no one cares what YOU do!
So you do you, someplace else please!
Old May 28, 2026 | 07:10 PM
Rounders's Avatar
Rounders
Teach a man to fish. I told him the connectors and location are listed in manual. So I don't even know why you are replying. Just to stir up crap.
I didn't know page was there for a long time . Handy page to find.
Old May 28, 2026 | 10:10 PM
HoosierWagon
Yeah, I posted here after finding the manual unhelpful. I found that connector in front of the very bottom of the battery, only visible when lying on the floor. I never saw
that described anywhere. But it’s good to post here and get confirmation. If the tuner ever gets here I’ll plug it in and hopefully something worthwhile will happen.
