Dyna Glide ModelsSuper Glide, Super Glide Sport, Super Glide Custom, Dyna Glide Convertible, Super Glide T-Sport, Dyna Glide Police, Dyna Switchback, Low Rider, Street Bob, Fat Bob and Wide Glide.
My 2014 FXDL is leaking at the fork seal. While ordering parts, I realized that I do not know what weight and amount of fork oil to get.
First, the service manual does not even list the FXDL fork oil capacity.
Second, I bought the bike after the front suspension had already been upgraded.
The PO put in +2 tubes with Patriot Suspension American Genesis Springs.
While the +2 fork tubes shouldnt really change the capacity, I am reading mixed comments on the genesis springs changing fork tube oil capacity.
Unfortunately, I cannot find any instructions for those springs either.
Does anyone have any recommendations for fluid weight and amount in this situation?
The fork oil level is measured from the top of the tube down to the oil, so the quantity of oil needed would be increased.
Never do it that way on any fluid, because you don`t know if the right amount was in there to begin with.
The service manual will tell you how much to put in initially, then the level is set using a fork oil level tool, they are cheap.
The fork oil level is measured with the tubes collapsed into the sliders, springs and spacers not installed.
The service manual does not list the FXDL. I am wondering if the capacity is different because the genesis springs are dual-springs. Wouldnt that increase spring displacement and later the fluid amount?
They took it out on the 14 or are you using a crappy manual? Or you didn't know where to look?
Out of the 13 manual..
The whole purpose of filling to a certain level is to create a bottoming out space where the volume of air can create enough pressure to stop the hard bottom.
"and later the fluid amount?"
Yes, It will change if the volume of the OEM removed springs and spacers is smaller than the what went in. To do it right you need to measure the difference in volume of the 2 setups. Second would be to measure the volume of current springs and spacers and calculate the volume needed plus some space to keep the fork from hydraulicing.
I owned a 2016 FXWG. It has the same fork tubes 49mm. I replaced springs with Progressive. They are denser than stock which raised the oil level.
Heres what I did to get the dampening I liked:
Removed forks and springs. Let oil drain overnight with forks upside down.
Installed the forks. Filled with proper ounces 10w oil. Use the table 2-14. 26.8 ounces for FXDL. Inserted the springs.
Put zip tie around top of forks. Went for a ride hard front braking. Measured the fork travel. Started with 5 inches.
If rode too stiff, travel was less. I removed fork caps and sucked out an ounce using measuring tool from Amazon.
Went for another ride until dampening was the way I liked. Remeasured the travel it was 5 1/8 inch. Your FXDL specs say 5.1 inches.
The oil level in the forks is set without springs or spacers installed.....
Yes, but the correct level depends in part on how much oil the volume of the springs displaces. If the spring has more coils per inch then it will displace more oil and the correct level will be lower. The level in the FSM is only correct if you have factory original springs (or your replacement springs displace the same amount of oil.)
That said, the spring manufacturer should tell you how you need to adjust the level from stock.
True, measuring with tubes collapsed. Good starting point. But I found it still needed further testing because changing springs can affect the level.
I poured in the oil specified 26.8. Installed the forks, the springs, spacers, caps an went for a ride. Then went by travel and the way it rode.
I had to suck out an ounce because denser springs raised the oil level and shortened the travel
