I have a screw loose.
Old Jun 8, 2026 | 10:37 AM
D4tini's Avatar
D4tini
Default I have a screw loose.
Has anyone run into this issue. It’s happened on both my 21 CVO and on my new 25 trike. It’s the bolt attached to the upper dog bone. Engine stabilizer.
Old Jun 8, 2026 | 11:50 AM
touchdown's Avatar
touchdown
take it back to the dealer
Old Jun 8, 2026 | 12:02 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Yes, while I was on a trip 2 years ago I noticed a squeak when the engine decelerated, turns out that part was broken (the nut that is welded on was gone).
I called the local dealer (HD of Hartford CT), they overnighted the part and replaced it the next morning (the machine was still under warranty at the time).
No issues with the same part on my `19 Electra Glide Standard.
Old Jun 8, 2026 | 01:07 PM
Jackie Paper's Avatar
Jackie Paper
Sure looks like the bolt is damaged also. Is that one of those critical fastners they check at the 1K preventive maintenance.
Old Jun 8, 2026 | 04:23 PM
NorthWestern's Avatar
NorthWestern
Make sure all bolts are secure. Part of the deal.
Old Jun 8, 2026 | 05:03 PM
JimL_15 Electra Glide's Avatar
I bet they just pencil whip those inspections to get maximum dollars for minimum payout for the flat rate mech.
Old Jun 9, 2026 | 12:56 PM
98glider's Avatar
98glider
I had the same problem pencil wipping the maintenance check list. I new that the spark plug wire was damaged and going in for service so I let the service dept look for it and behold checked it off and said it was ok and I called them out on it that is faulty. Do you know the service writer gave me the hard time for not pointing it out. I bought 2 new wires there and installed them myself in front of the garage and left the bad ones there on the ground. This is why you have to be mechanic sometimes cause you cannot trust no one
Old Jun 9, 2026 | 03:52 PM
Fender62's Avatar
Fender62
Pencil Whipping is a term I haven't heard in a long time. I know exactly what it means but in my 26 yrs in the Air Force and most of that working on Jets, I didn't do it. I worked weapons and weapon system and the ramifications were too costly. However, a Tech at the local dealership that may be disgruntled or not making what he/she believes that should make, is ripe for "Pencil Whipping" a checklist. Not saying the all do it, as I believe integrity is not dead yet but maybe not as prevalent in the workforce as it once was.
Old Yesterday | 09:22 PM
Oh hell a BB Stacker... Yes it was Air Force 20 years. F15C,D, KC-135 A & R Crew Chief here.
Old Yesterday | 09:42 PM
Fender62's Avatar
Fender62
Not a BB stacker, Muzzle F'er is the the moniker. LOL
30glock
Screamin Eagle CVO Models
94
Jun 24, 2024 12:40 PM
Irishguy1973
Apr 8, 2023 12:59 PM
Rickpiet
Jul 6, 2021 07:21 AM
DRBUICK
Milwaukee Eight (M8)
32
May 10, 2019 06:43 AM
monster715
Engine Mechanical Topics
Jun 20, 2017 08:42 AM
