2018+ Softail Models Breakout
2025+ Softtails oil blow by
Old Jun 14, 2026 | 06:56 AM
VA_Larry's Avatar
VA_Larry
Default 2025+ Softtails oil blow by
I was chatting with a dealer tech yesterday and he mentioned an issue with the new Softtails: they were seeing a lot of complaints for oil blow by even when the dip stick wasn’t indicating over filled oil.
HD recently released a replacement dip stick for these models. Apparently the original dip stick was marked wrong and indeed people were over filling their bikes. Additionally, checking the oil level is now done with the kickstand up and engine warm. Checking on the kickstand, as we have done forever, will give a low oil indication.
Check your owner’s manual for the process and inquire about the new dip stick.
Old Jun 14, 2026 | 09:07 AM
hattitude's Avatar
hattitude
Interesting.....
HD changed from the #62700226 dip stick in '24 (and earlier M8 softails), to the #62700380 dipstick in '25 & '26....
Not sure why the need for the change. I wonder if they are going back to the #62700226?
Old Jun 14, 2026 | 07:02 PM
Jackie Paper's Avatar
Jackie Paper
https://www.hdforums.com/forum/2018-...-dipstick.html
Just how far up on a dip stick does oil have to be that the engine would get enough oil to make it sump and vent oil into the head breather with a oil sump under a transmission?
When you check the transmission fluid on the 2015 TCb Softail, do you screw the stick in or rest it on top of the casting? How do you do it on a 2025 M8 transmission?
Old Jun 16, 2026 | 12:25 PM
lowbar's Avatar
lowbar
Oil Check Quick Reference Guide and referenced Service Bulletin M1697. The M1731 doc is from MS Copilot AI.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 17, 2026 | 12:09 AM
Powermankw's Avatar
Powermankw
But I don't want to measure it upright. What does it show on jiffy stand full hot. Surely it's not off dipstick? Should be like halfway. I'll have to see for myself.
Don60
Oct 3, 2022 08:03 AM
Pale Horse Rider
Jan 15, 2015 12:05 PM
Taildragger NC
Jan 23, 2013 09:46 AM
DK Custom
Oil Archive (no new posts)
Mar 31, 2012 05:26 PM
PewterHeritage
Aug 30, 2009 10:14 AM
