Stator Connector Leaking Fix?
Old Jun 17, 2026 | 12:12 PM
Highwayman99's Avatar
Highwayman99
Default Stator Connector Leaking Fix?
I have a 99 Softail Custom, there is oil leaking out of the stator connector. Is there a fix for this without replacing the stator? I have sprayed it with brake cleaner hoping that swells it for now. Obviously this is a common problem.
Old Jun 17, 2026 | 01:58 PM
YZR's Avatar
YZR
I had this issue on two softails. My fix was to clean it as much as possible (I used brake cleaner), let it dry out overnight and seal it using high-temp RTV.
This has held up nicely on both occasions.
Old Jun 17, 2026 | 02:05 PM
Rounders's Avatar
Rounders
It is a Harley problem. As said some try to rtv it.
Old Jun 18, 2026 | 09:13 AM
MotoJockey's Avatar
MotoJockey
I used Permatex Ultra Black on my 03 RKC about 5-6 years ago with no issues since..........
Old Jun 18, 2026 | 01:34 PM
memphisharley's Avatar
memphisharley
after cleaning it well try some permatex flowable silicone.
Old Jun 18, 2026 | 02:18 PM
Jackie Paper's Avatar
Jackie Paper
Permatex Ultra Black. Make sure to also check that transmission vent down tube.
Old Jun 20, 2026 | 06:24 PM
roussfam's Avatar
roussfam
As already mentioned, I use a pick to pull the flange of the grommet away from the case, and I spray brake cleaner around, and I try to give it a bit of a scrub with an old toothbrush all the way around at the same time.
I usually pick up a pack of those small tipped arts and crafts paint brushes from the dollar store. While using the pick to pull the flange of the grommet away, I brush a little black RTV all the way around.
Old Yesterday | 06:00 AM
RANGER73's Avatar
RANGER73
This was a mistake, the brake cleaner will eat the rubber plug. Ask me how I know.
You've just made your problem worse. You should have just cleaned it and them use the Ultra Black like suggested.
Old Yesterday | 10:13 PM
MotoJockey's Avatar
MotoJockey
I used the green can of Brakleen (CA Compliant) on my RKC mentioned above and then dried it with a can of keyboard duster. Like I said, 5-6 years ago without the slightest seep. YMMV......
spyd3rm4n
Twin Cam Motors
May 19, 2026 10:20 PM
Runamuk13
May 4, 2021 06:05 PM
Bingee
Aug 25, 2015 09:54 AM
Tx_Rider
Jan 9, 2014 08:58 AM
scrawfordFLSTC
Oct 9, 2007 09:41 AM
