engine guard - conventinal or mustache
Old Sep 22, 2014 | 09:15 PM
MacKenzie001's Avatar
MacKenzie001
Conventional for sure, looks better and with the "chaps" on them its good for keeping wind/rain off your feet and lower legs.
Old Sep 22, 2014 | 11:10 PM
Snowyone's Avatar
Snowyone
Red face guardian
Mustache bar for me on my Fatboy and Crossbones. It give the left leg a spot to hang out but the right leg needs another joint to get around the air cleaners. Both protect in a fall over(personally tested) and me thinks the mustache might be just a bit tougher with the extra bends. Makes setting the bike back up easier to.
Old Sep 23, 2014 | 01:31 PM
Tx911guy's Avatar
Tx911guy
My Heritage has a chrome mustache bar on it and I think it looks fine.
Old Sep 23, 2014 | 02:08 PM
proraptor's Avatar
proraptor
Conventional looks a lot better IMO
Old Sep 23, 2014 | 07:02 PM
MikeZ's Avatar
MikeZ
My vote would be for the nostalgic bars.
Old Sep 24, 2014 | 02:13 AM
standardmoose's Avatar
standardmoose
got mustache bars on my lo, i like the look as it sort of blends in with the boards and such, but some times i have thought about changing to classic bars but then again i think it would change the look, so it think its all down to preference, and like most people said, if its a simple drop then both with probably do the same but if its a big drop/slide/crash then they both will probably do the same or not really matter.
Old Oct 17, 2014 | 05:33 PM
RockerHD's Avatar
RockerHD
1st Gear
Default HD highway bar on FB
Hi, guys! After seeing so many terrific pictures, I decided on the conventional one, and got a genuin HD conventional highway bar from a local dealership for my FB. It looks great on the bike. Now, I have some installtion question. I once put it on the bike and ran half a day and remove it. I saw some gouged marks on the bike-side mount bracket, and this was caused by rough edges of the bar-side mount plate. The contact surface of the mount plate is not perfectly flat, and the edge is raised by 0.5 mm or so, probably due to a manufacturing process. I grinded the edge at right hand side and rust-proof painted it, which caused the biggest gouged mark. I'm thinking to grind all the remaing edge of the plate so that it won't gouge the bike-side bracket and I won't have any rust issue later on. How would you think of this? Any comment is appreciated.
RockerHD
Old Oct 18, 2014 | 05:48 PM
a99miata's Avatar
a99miata
I mustache you why you want our opinion?
Old Oct 18, 2014 | 05:55 PM
mmcbeat's Avatar
mmcbeat
Depends on the bike. I had a standard Lindby on my Deluxe and really liked it.
Old Oct 18, 2014 | 10:28 PM
oct1949's Avatar
oct1949
each bike has its own needs.. I like Nostalgia on my bike.. others you have to pick whats right for you
