Hogpro has some front fenders (over $100 less than the heartland.) The Long Tapered and Short Tapered. They fit the wide glide front end and are direct bolt on.
I was wonder if that's the wild heart fender from heartland, and can I put on a Lepera Barebones seat on the fender with out modification?
Nope the wild heart fender ends right after the struts do. I have the wild heart fender on my bike but I'm currently in the process of going with a custom fender reuseing my heartland struts
the thunderbike ones are pretty nasty! if i had a breakout i think i would go with the thunderbike rear fender. i do like the heartland style too, but i think they look better on the fatboy's. if i did a heartland i would probably go with the wild heart for the breakout to show off that rear tire
It's an interesting looking fender. Looks like it's designed to use the factory struts. While this is convenient, they had to extend the fender mounting a bit to accommodate it. This also means it is not markedly shorter than factory. The pic has the factory seat, but the notes say that custom seat mounting is required, so it may not have the holes already drilled. Oddly, it does look like it has a hole for the pillion bolt though.
