high pitched whine on decelleration
Old Oct 3, 2014 | 06:27 AM
Jameson's Avatar
Jameson
Default high pitched whine on decelleration
After I installed my rear wheel I have started getting a loud whine on decelleration. I'm guessing it could be my belt adjustment? My bike has a shotgun shock. When I adjusted the belt it was on a lift so the swing arm was fully extended. I ride with it an inch or so up from slammed. Should I adjust the belt at ride height or does it no matter? What's the correct procedure for belt adjustment? Thanks guys
Old Oct 3, 2014 | 08:12 AM
mkenkel's Avatar
mkenkel
the first thing I would ck is wheel alignment if you moved the adjusters when removing the wheel. second I would adjust the belt tension with the bike on the ground and set at ride height. but if I was gonna bet it would be on the belt tension being to tight .good luck.
Old Oct 3, 2014 | 08:19 AM
Bone Doc's Avatar
Bone Doc
Your service manual explains it in detail.
Old Oct 3, 2014 | 10:34 AM
mkenkel's Avatar
mkenkel
sorry jameson, I started typing before I got to your actual question. as the good doc points out the procedure is in the manual. Harley sells what they call a belt deflection tool that you can get at the dealer. a lot of old timers say if you can take the belt between your thumb and fore finger and twist it at a 45degree angle then your good.
Old Oct 3, 2014 | 10:43 AM
Jameson's Avatar
Jameson
Thanks guys. My belt was pretty loose. Just tightened it up and checked my alignment. All good and the whining is gone.
Old Oct 3, 2014 | 11:34 AM
klf33's Avatar
klf33
It is also normal to get that with 'lowered' bikes.. I have a detailed thread on that from last year
Old Oct 3, 2014 | 11:37 AM
klf33's Avatar
klf33
Here is a link to the discussion, others discussed it in the NightTrain pictures thread(subforum ).
https://www.hdforums.com/forum/softa...bbing-mmm.html
Iarecobra
May 7, 2017 01:09 AM
MooseMike
May 3, 2013 10:10 AM
37sportster
Mar 26, 2011 08:49 AM
BruinsFLHRS
Apr 10, 2008 02:44 PM
JaboIam
Feb 18, 2008 08:11 PM
