Riser install for first timer
Old Dec 5, 2014 | 12:33 AM
hattitude's Avatar
hattitude
Originally Posted by Pete3323
LMAO! You're so right, 'tude. Ordered American Custom slip ons today for my next project. Any advice on install?
Best advice... make sure you buy a service manual.
It will pay for itself many times over..
Have fun
Old Dec 5, 2014 | 07:39 AM
atrox88's Avatar
atrox88
Got my 4.5" risers on today. Just what I needed! Got them from J&P. Was able to reuse the stock top clamp which I like. Risers even came with cool little chrome covers for the top clamp bolts. Job was ez. Thanks for all the help...this forum rocks!
Did you end up doing the bushings to? I did mine without and the bars were crooked. You can see the misalignment where the risers meet the bushings.
I tried adjusting but that only helped so much. I am going to put the poly
bushings in tomorrow and see how that works out.
Old Dec 5, 2014 | 01:24 PM
Pete3323's Avatar
Pete3323
I didn't do the bushings. Mine were crooked at first too. Had to loosen them and re-tighten a couple times to get them right. I have the poly bushings but didn't use because I was concerned there might b more vibration in the bars without the rubber there. Anyway mine were in good shape.
Old Dec 6, 2014 | 08:56 AM
dfwhockey17's Avatar
dfwhockey17
^There will be minimal added vibration with the poly bushings, they do a very good job of absorbing the vibes but also keep the bars from moving. What bars did you put on again?
Old Dec 6, 2014 | 10:35 AM
HDmikie's Avatar
HDmikie
IIRC, the OP used his stock bars but added 4" risers.
Old Dec 6, 2014 | 02:42 PM
dfwhockey17
Ahhhh, then not as big of a deal as if apes were being put on....
Old Dec 6, 2014 | 08:40 PM
Pete3323's Avatar
Pete3323
Correct. Stock bars were used. After the install and test ride I decided I wanted to have the bars a bit closer so I loosened top clamp and adjusted and re-tightened. Well, I went to try it out today and those bars are crooked again! So tomorrow it comes apart and the poly's go in. I'll post up the results. Atrox, did you get yours in?
Old Dec 7, 2014 | 08:20 PM
Pete3323's Avatar
Pete3323
Installed drag specialties poly bushings today. Had to adjust a couple times to get em straight. No vibration issues and a nice solid feel. Very happy with the combo.
Old Dec 8, 2014 | 06:09 AM
atrox88's Avatar
atrox88
No, I really got lazy this weekend. I am leaving work early today to do it.
SPARKY01
Oct 21, 2015 09:11 PM
NLGangster
Feb 24, 2012 09:34 AM
SgtMic
May 5, 2010 05:00 PM
H20DOG
Jul 1, 2009 02:45 PM
OneBlackFly
Nov 2, 2007 11:42 AM
