Fuel Tank
Old Sep 13, 2005 | 12:00 PM
dert's Avatar
dert
Default Fuel Tank
92 FLSTC dual tanks.I was riding the other day and it started to stall as I throttled it,.Approached an incline and it died.I backed it down and attempted to restart it.No go.I checked the tanks and there was some fuel .,but not much.I checked the valve for correct position.Pushed it a block up up the street and had a buddy lookat it.. Learned a new trick .If its low on fuel and on an incline,fuel doesnt reach the valve.Level it out and lay it on its left side for a minute or so ,and gas will drain from right to left . Also I have been told contradicting fuel valve **** positions. There is an arrow on the long part of the handle pointing in the direction away from the long section.The handle downward and arrow pointing up to the on position.Make sense ? I was told that this actually in the reserve position .Comments ?.Wish I could draw a picture .Their way seems wrong .Or am I ?
Old Sep 13, 2005 | 12:03 PM
HDF Tech's Avatar
HDF Tech
Default RE: Fuel Tank
I've always used the arrow to point at the selection that I wanted, reserve, main etc.
Old Sep 13, 2005 | 12:25 PM
dert's Avatar
dert
Thank you TCSTD,glad you stayed .Ive been out in the lot between patients looking at it again.You confirmed my "rightness" .
MJHJEA
EVO
11
Sep 5, 2014 06:47 PM
Harley_Charley
Jan 4, 2014 08:31 PM
Timothy Houser
May 24, 2011 09:08 PM
Tiggeresq
Mar 27, 2007 02:33 PM
DAILYRDR
Exhaust System Topics
Jan 15, 2007 12:45 PM
