about to pull the trigger on an oil bud
So in an oil cooler, the hot oil enters the cooler. Heat transfers from the oil to the heat exchange medium, and from there to atmosphere (atmosphere not meaning the air exclusively). If it's a convective type cooler, the heat transfers into the tubes, out to the fins, and then to the air flowing across the fins. If it's a radiant cooler, the heat transfers into the body of the radiant cooler and then radiates out in all directions, just as light radiates, and is absorbed into objects in its path. Radiant rays even reflect just as light rays reflect. This is why if you placed 2 identical items in direct sunlight, one of them black and the other white, the black one will become much hotter. The black item will absorb a lot more of the radiant heat than the white object will, simply because the white object will reflect a lot of the radiant rays, just like it would reflect light rays.
As far as being next to a heat source goes, it can have little to almost no effect, or it could have a great effect. You'd have to give me specifics for me to even try to answer. If we're still talking about the Oil Bud and the heat source is the bottom of the engine, I'll just have to give my best guess as I've never researched it or tested one.
On the convective end, it shouldn't amount to a hill of beans. When the bike is rolling, all of the heat pulled out by convection is going straight out the back and there's a layer of incoming cool air moving in between the heat exchanger and the bottom of the engine.
On the radiant end, it gets a little trickier. The proximity of the hot engine will technically lessen the amount of radiant heat given up by the top of the Oil Bud. How much, I have no idea without all kinds of brain-breaking calculations that I'm not about to do. It won't effect the radiant heat coming out of the bottom of the Oil Bud and it definitely isn't going to put heat into the oil. That's the best I can do there.
I hope it makes sense after all of this typing.
Whether pressure drop is an actual concern with the Oil Bud cooler, I don't know. Never looked at one.
Beyond that, exactly what do you think happens when the spring pressure is exceeded? Oil certainly doesn't get "shut off" from anywhere. Excess oil is simply diverted. There is still full flow, throughout the engine, at the dedicated spring pressure. These pumps make a good deal more pressure than the dedicated spring pressure. The excess is simply diverted. By design.
