Newbie
Old Dec 24, 2014 | 09:52 AM
BlackDiamond2013's Avatar
BlackDiamond2013
Stage I
Question Newbie
Hello,
My name is Angie and I am new to this forum, looking for guidance and tips on doing some work to my 05 Harley night train. I wanted to change my tire from 150 to a 200... Any advice?
Old Dec 24, 2014 | 10:14 AM
Next In Line's Avatar
Next In Line
Heartland 180 install=start to finish
Old Dec 24, 2014 | 11:08 AM
Ramboamt's Avatar
Ramboamt
Hello and welcome to the forum. You came to the right place for advise.
Old Dec 24, 2014 | 02:29 PM
magna's Avatar
magna
http://heartlandbiker.com/wide-tire-...inkle-struts-5
Old Dec 25, 2014 | 06:27 AM
stal94gt's Avatar
stal94gt
That wide tire kit is expensive. Do your research and keep your eye open for 07 and up take off parts
Old Dec 25, 2014 | 07:15 AM
cocky's Avatar
cocky
Hello and good luck.
Old Dec 25, 2014 | 11:02 AM
Snowyone's Avatar
Snowyone
Default don't do it
My advice is don't do it. In my experience with 200 tires is dismal because they wear out too quickly plus it's expensive and a bunch of work to do. Handling wise I would not exceed the 180 barrier as it seems to be about the best compromise for the wide tire look and makes it easier to initiate turns and hold your lines. You would need to do some measuring and checking various tire brands but you might fudge and fit a bigger tire in without doing a bunch of mods. I know on my 80 FXWG I went from 130 to a 150 with no problems, and on my 84FLHTC went to a 140, and on my 02FLT went to a 140 so do some measuring. Merry Christmas and welcome.
Old Dec 25, 2014 | 04:59 PM
tbonetony06's Avatar
tbonetony06
Welcome Angie! I have to agree, I wouldn't do it BUT its ultimately your bike, your coin. As long as it is bad *** to you, nothing else matters.
But, and again, you came to the right place. Check out the vendor directory and you will talk to some knowledgeable people and who can probably find you anything you wanted.
Old Dec 26, 2014 | 03:50 PM
olongapo1's Avatar
olongapo1
Angie,
Snowyone's advice is spot on. Modifying your 05 Train to mount a 200 rear tire is very costly and labor intensive. Not much bang for the buck other than looks. I recommend changing your front tire from a 90 series to a 120. Gives the bike much better handling characteristics. You'll need to change to a wider front rim and fender. Minor cost resulting in substantial results.
There are numerous other beneficial modifications you can invest in other than the wide tire kit. Here are a couple pics of my 03 Train.
Attached Thumbnails Newbie-r0015868.jpg   Newbie-r0015874.jpg   Newbie-r0015877.jpg
jerryinpa
Welcome Area Only
14
Jul 27, 2016 12:31 AM
cjbramlett
Welcome Area Only
11
Jun 27, 2012 03:53 PM
pjchamp
Welcome Area Only
16
Oct 25, 2011 07:19 PM
timid
Welcome Area Only
21
Jun 15, 2010 12:47 PM
tep3
Welcome Area Only
26
Sep 20, 2008 11:01 PM
