Motorcycle Jacks
Old Jan 21, 2015 | 06:21 PM
Sully103's Avatar
Sully103
Default Motorcycle Jacks
Does anyone have a good lead on a motorcycle jack? I got a great one from Sears, rated at 1500#s but the darn thing won't fit under my Softail or Nightster. Go figure, I never thought to measure the minimum height I needed before buying the thing and tossing the receipt. Thanks.
Old Jan 21, 2015 | 06:34 PM
tafdeluxe's Avatar
tafdeluxe
Default fix??
My 2011 Deluxe lower than my 2004 Heritage. Now I put two rectangular pieces of thick plywood 1" maybe in front of both wheels and roll it up on them. Jack just fits.
Old Jan 21, 2015 | 06:40 PM
Sully103's Avatar
Sully103
I will give it a try. Thanks.
Old Jan 21, 2015 | 06:47 PM
Bone Doc's Avatar
Bone Doc
My guess is you bought the Sears red jack. I have the Sears yellow jack and it rolls under my Heritage without a problem.
Old Jan 21, 2015 | 07:20 PM
Bluraven's Avatar
Bluraven
I had the Sears red jack and it fit under my Heritage if the bike was upright.
I liked the Sears red jack a lot but I wanted to be able to hang the jack on the wall and it was just too heavy.
I came across a used Sears yellow jack and it not only is light enough to hang it fits under my Heritage with it on the jiffy stand.
Just get you a 2X6 and roll the front tire onto it and that should give you enough clearance for the jack.
Old Jan 21, 2015 | 11:20 PM
Gommee's Avatar
Gommee
Devil's Advocate
Do you put any spacers under the frame so that the the jack does not push on the shocks?
I have the red jack and a pair of scissor jacks and I use a 3/4" piece of rubber under the frame to keep pressure off of the shocks.
Old Jan 22, 2015 | 08:53 AM
mkenkel's Avatar
mkenkel
I had a lowered deluxe that my jack wouldn't go under so I took a piece of 2x8 about 16''long and cut a 45 degree angle on the front of it making a ramp. I screwed a piece of 1x2 across the back for a stop and it worked like a charm.
Old Jan 22, 2015 | 12:50 PM
jam436's Avatar
jam436
I have the Sears red as well, and I found that with my Slim I had to stand the bike upright with one hand while sliding the jack under with the other - either that or get some help.
It was a tight fit but it fit, barely.
Now with a Shotgun that problem has gone away...
Old Jan 22, 2015 | 12:55 PM
JerryW's Avatar
JerryW
I'm close by if you're looking for a better jack.
https://www.hdforums.com/forum/the-f...west-palm.html
STREAK
Product Reviews
May 26, 2022 08:22 AM
Sash302
Dec 10, 2014 08:06 AM
Firefighter0763
Jul 17, 2014 09:50 PM
BigMESA
Feb 17, 2014 08:10 AM
FishingT
Aug 15, 2008 02:30 PM
