Never Noticed This About HD Wheels
Old Jan 24, 2015 | 08:38 PM
MNtadpole's Avatar
MNtadpole
Default Never Noticed This About HD Wheels
So I just recently picked up my new 2015 Slim and noticed for the first time that wheel balancing weights were installed on the side of the wheel rim. Is this normal for HD wheels? I can't imaging someone getting a set of custom chrome wheels and have some ugly weights glued to the chrome... What's more, I noticed one weight was loose to the touch. Any suggestion on correcting that? I'm thing some double sided foam tape.
Old Jan 24, 2015 | 09:01 PM
jreichart's Avatar
jreichart
All wheels/tires need balancing to some extent. Lots of guys ditch the weights and run dyna beads.
Old Jan 24, 2015 | 09:10 PM
QC's Avatar
QC
I've thrown a couple stick on weights and have gone to Dyna Beads.
https://www.google.com/url?sa=t&rct=...84349003,d.aWw
Old Jan 24, 2015 | 09:22 PM
Gommee's Avatar
Gommee
Devil's Advocate
Another for the use of Dyna Beads.
It sucks getting hit by a flying weight...
Old Jan 24, 2015 | 09:25 PM
Pudge211's Avatar
Pudge211
Mine get painted black before they stick them on. Barely noticable
Old Jan 24, 2015 | 09:41 PM
Alain's Avatar
Alain
The ones on my CVO breakout wheels are black to begin with and you can barely notice them
Old Jan 24, 2015 | 09:47 PM
RANGER73's Avatar
RANGER73
Another one with Dyan Beads here.
Old Jan 24, 2015 | 11:06 PM
balloo's Avatar
balloo
The dealer should fix the loose weight, and I would insist that they check the balance, just in case the weight came of and someone just stuck it back on.
Old Jan 25, 2015 | 04:31 AM
Rodzilla6's Avatar
Rodzilla6
I switched over to DYNABEADS a few years ago and have never had an issue. No marks on your rim...
Old Jan 25, 2015 | 06:27 AM
Softail HA's Avatar
Softail HA
The wheels are balanced as part of dealer prep package I believe, if you catch it early enough Harley makes some nice chrome wheel weights, or if you have spokes you can opt for the ones that clamp onto the spokes . They are more expensive so the dealer will not usually do it unless you ask. Dyna beads, and ride on are great products but my dealer will not use them for liability issues.
