FP3 tuning???
The bike will run less than optimal in AutoTune, it's the same way with the SEPST SmartTune.
My understanding is that in AutoTune, the tuner loads the bike's "defaults" from the factory in order to compute the changes - so if you've changed pipes and A/C, the bike will run like crap...
Your AutoTune fill looks like it's more full than I ever got, and I ran it three or four times.
The thing about AutoTune is that it seems to only help if you run it once or twice.
Any more than that and you're just making small changes to cells that may have already been changed before.
ie; the conditions on each run are probably more different than alike.
I found the first suggested map for my bike (Slim, S&S Super free-flow A/C, V&H BBS's) was probably the best of them all.
I ran a few Autotune passes just for the hell of it, and didn't really see much improvement over the first map, which was sensational.
So even after a few AutoTune runs (just to try it, to be honest) I just went back to that first map and left it alone ever since.
I just can't imagine the feel of the bike improving any more over what I have now...
My oil temps dropped significantly, decel pop was completely eliminated, more power all around, my MPG returned to a more respectable 40+ (after that garbage dealer-installed Stage 1 download) and it even sounded better.
The FP3 was hands down some of the best $$ I spent on this bike so far...
I will run another tank or so through it with different types of riding and see how it all ends up.
The main thing that concerns me is that the temps is much higher, 270-300 while using the autotune and while in the baseline Big Radius map they supply it is around 240-260. The way it runs also is unpredictable as it can run strong to weak, very inconsistent. I hope to get it running consistently strong and cool, I don't want to be forced to upgrade to a 120r by blowing up my new 103
)You can call V&H and give them some info on your bike; they will pull up your map and tweak it for you based on their experience vs. your bike setup. I have not done that yet.
Oh yeah, the bike runs great. Be sure to check out the throttle lag setting. It makes a huge difference in response, especially when going into passing mode.
So it seems like I bought the FP3 to just upload the map they say to use. Bike runs good but have not really ridden it a whole lot yet.
Good luck!
Good luck!
