Engine shutdown at 70!
Old Apr 19, 2007 | 06:23 AM
deluxe's Avatar
deluxe
Default Engine shutdown at 70!
Bike had been warmed up for about 10mins. It was about 5 deg C outside. I was 10 mile into my ride to work and the bike completely shutdown on me. The engine warning light flashed a couple of times, so I stuck her neutral and pulled over. Shut everything off, restarted and she purred all the way the rest of the journey (65 miles). Anyone had this happen to them. Any idea what it may be? Is it a dealer question.
Any suggestions will be gratefully recieved
Regards
Rob
Old Apr 19, 2007 | 07:59 AM
deadeye's Avatar
deadeye
Default RE: Engine shutdown at 70!
What bike you got, carb or EFI? I had the exact same thing happen to me on a rented, carbed Duece. Going about 60mph and it suddenly died. After I rolled to a stop, it started right back up again. I thought vapor lock?
Old Apr 19, 2007 | 08:56 AM
flst06's Avatar
flst06
This happened to a friend of mine on a RoadGlide. It was the aftermarket ignition module he was using.
Old Apr 19, 2007 | 11:42 AM
Oldtimer of NM's Avatar
Oldtimer of NM
There is an off chance that this could be caused by a loose battery cable connection. Doesn't cost anything to check, especially the frame end of the ground cable. If it rattles around a little, just enough to cause some voltage spikes, it wull cause the ignition module to reset.
Old Apr 19, 2007 | 01:39 PM
deluxe's Avatar
deluxe
The bike is a '06 Deluxe with EFI.
lynamb
Mar 18, 2018 10:04 AM
OwnerOfHarriet
Jun 7, 2014 08:33 AM
smallhog
May 3, 2013 12:38 PM
rking2000
Jan 30, 2008 11:59 AM
sledman583
Aug 24, 2005 09:33 AM
