Softail troubles
Old Apr 19, 2007 | 10:01 PM
xlr841's Avatar
xlr841
Stage I
Default Softail troubles
Please repost , or let me know of the fires that were happening to the FB, wife is getting a 07 and I want to let the dealer I kow of this
thanks
rick
Old Apr 19, 2007 | 10:55 PM
jhugs92's Avatar
jhugs92
Default RE: Softail troubles
only one that i have heard of was the battery cable grounding against the frame and ultimately sending current through the steel braided oil lines from the oil tank and smoking the braiding.
Old Apr 20, 2007 | 12:20 AM
Oldtimer of NM's Avatar
Oldtimer of NM
The oil tank is on rubber mounts, so it is insulated from the frame.
If the battery is not properly installed or the + cable insulation is damaged, it can short to the oil tank. If this happens on a bike equipped with braided oil lines, they carry the full battery current to the grounded engine case. The battery is big enough to cause the braided lines to heat up to the point that the internal rubber part melts, dumping oil onto the braiding, which is hot enough to ignite the oil.
If the battery shorts to the oil tank on a bike with rubber oil lines, you might not notice it until you drop a wrench or something and it welds itself between the tank and frame.
Old Apr 20, 2007 | 12:44 AM
wild2hunt's Avatar
wild2hunt
Stage IV
XLR841-
I am one of the unfortunate ones that had the battery short out on the frame/ oil tank. The critical issue is to ensure that the plastic sheath protects the positive battery terminal wiring. I believe that my bike was shipped from the factory with the plastic installed too low thus allowing the frame to rub a hole in the wiring and causing the short which leads to excessive current running through the braided oil lines. I was riding my bike when the first oil line 'burned'.
Have the dealer inspect the battery wiring with youbefore you purchase the bike. If you have a battery tender or any other add-ons installed re-check the wiring. After reading about this problem on the internet, I was shocked that my dealer had "Never heard of this happening". MOCO did not seem especially helpful until I put together an 'engineering style' memo with pictures, timelines and analysis. The dealer purchased a new bike for me from another dealer and probably fixed the bike and sold as used.
Good luck.
Old Apr 20, 2007 | 12:56 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Oldtimer of NM is right, and its easy to prevent. All you needc to do is wedgea pieceofplastic insulationbetween thepositive terminal/wire and the top tank edge.
That will hold the battery terminal in placeand prevent the weld (its a little rough) on the top insideedge of the tank from abradingits way throughthe wire insulation and shorting out.
Do a search of the forums and you'll find that its been covered extensivly before at least twice that I know of recently.
And tell the Mrs,. we said to have fun, and post some pics of her and it when she gets it.
Ride Safe. [sm=biker2.gif]
peescal
Ironhead
Jun 27, 2010 10:05 PM
ROMPUS
Jun 1, 2010 10:24 AM
rino
Mar 12, 2008 03:31 PM
SmokinEd
Aug 20, 2007 11:44 PM
SmokinEd
Aug 19, 2007 12:44 AM
