derby cover
Old Mar 20, 2015 | 07:49 PM
janderson1964's Avatar
janderson1964
Default derby cover
I am swapping my primary cover. Got the gasket cover and oil coming. I realize i need to refill the oil through the derby cover. Do i need a new gasket for the derby cover as well.
Old Mar 20, 2015 | 08:02 PM
cruzomatic's Avatar
cruzomatic
No new gasket is needed. Simply reuse the one that's there now if it's in good shape of course.
Old Mar 20, 2015 | 08:05 PM
IrIeSpringer420's Avatar
IrIeSpringer420
ya you should be good. if you have the disk gasket just make sure the rubber orange part is looking nice and clean
Old Mar 20, 2015 | 08:09 PM
Harley Rookie's Avatar
Harley Rookie
6th Gear
If you are only changing the derby cover you only need to replace the gasket behind it. If you are changing the oil in the primary then you would need to replace the inspection gasket.
Shooter1975
Mar 26, 2016 04:49 PM
thoner7
Dec 21, 2013 07:35 PM
HDluxy
Aug 12, 2008 04:16 PM
SteelTree
Apr 23, 2007 04:02 PM
mysticwolf
Apr 4, 2007 12:39 PM
