Decel popping
It didn't pop before with my 2 into 1 on there either.
I also agree, that's exactly what my bike does now, bwaaaaaaaaaaaaaaa.
EDIT: I would not take my bike to a Harley dealer for nothing even if it were free, I would push my bike right past them to get to a trustworthy mechanic.
"First, when you close the throttle, you are also closing the throttle plates. This reduces the air and fuel flowing into the motor, and increases the vacuum (lowers the pressure). This results in less air and fuel in the cylinder during the power stroke, which in turn results in a lower pressure in the combustion chamber. Remember that the A/F mix burns faster in proportion to the pressure applied. Well, when we reduce pressure this way, the mix burns slower. This results in two things happening.
1. The lower burning fuel generates less heat, and the cooling effect of the non-burning fuel tends to “quench” the flame front, or slow it down even further. Because the mix is burning much slower, the exhaust valve can open before all the fuel is consumed, and the unburnt fuel is ejected into the exhaust.
2. The engine designers, in order to promote smoother idling and better combustion, retard the spark when the throttle is shut, and this results in the mix being lit later.
So, now we end up with unburnt fuel in the exhaust, and burning fuel being ejected into the exhaust, and bang! Backfire."
Remember HD sends the bikes out LEAN to have a low emission total for the bikes they sell.
Our '06 Sporty was carbed and it was overly lean and ran hot and decal popped like a **** until I re-jetted the carb to larger jets and the decal pop and the running hot went away plus, would you believe it, I got better mileage.
TBone, since your bike does not decal POP I'll take it off your hands for $500.00 plus shipping since it is defective and does not POP... LOL ...
My theory is what I have preached for years, head work with cams to match, auto tuner and putting it on the Dyno. No raw gas is getting past my heads.
I could be wrong but that's what I'm thinking.
