Breakout-riser spacers
Old Apr 20, 2015 | 06:39 PM
Dalt10's Avatar
Dalt10
Default Breakout-riser spacers
I just installed a set of 1 1/2" chrome spacers on my risers. That little bit of a spacer makes a difference. I like the drag bars but wanted them a little bit closer. Since they are a little up and back you aren't streching as much (I'm 6'2" so I didn't strectch to much anyway). Only thing I had to unhook was the Master Cylinder line from the frame. There was enough slack in all of the other cables.
Old Apr 20, 2015 | 06:49 PM
cdonis's Avatar
cdonis
Looks good.
Old Apr 20, 2015 | 07:35 PM
Beatz's Avatar
Beatz
Can I ask were you got your longer Riser Bolts? Must have went to around 4-4.5" or so?
Old Apr 20, 2015 | 07:45 PM
cdonis's Avatar
cdonis
Removed one of the stock ones and added the riser length to get the required length . Bought the bolts at Napa auto parts. That's what I did.
Old Apr 20, 2015 | 08:07 PM
Dalt10's Avatar
Dalt10
The bolts came with the spacers. Bought them on ebay and had the guy get the spacers chromed. Used my washers that were on the bike.
Old Apr 20, 2015 | 08:13 PM
Stone Cliff's Avatar
Stone Cliff
Where did you buy the spacers?
Old Apr 20, 2015 | 09:00 PM
Dalt10's Avatar
Dalt10
Got them from this guy. Read the whole add.
http://www.ebay.com/itm/Harley-David...item2c99fb30fa
Old Apr 20, 2015 | 10:28 PM
Stone Cliff
Thank you
Old May 22, 2015 | 03:25 PM
sincitychoppa's Avatar
sincitychoppa
I installed my 1.5" spacers today and the wires are EXTREMELY tight, even after un doing the zip ties. I wonder why yours are longer. I need to find a solution, do they make plus n play extension of any kind, someone should make a wire kit that does that for Harleys as a lot of people do risers and apes.
Old May 23, 2015 | 03:00 PM
Dalt10's Avatar
Dalt10
My brake line has a little wiggle room locked to the left but is not tight. Everything else is fine. My spacers are 1.5". If I went 2" I would had to change the front brake line.
