California Registration
I don't think it matters what the seller put on the paperwork. As long as it has 7500 before you register it.
For example, if you bought it and then drove it out of state for awhile and/or drove it to CA.... the paperwork would show you bought it on a certain date with 6190, but the bike would now be several weeks older and have over 7500 at the time of inspection....
The other potential issue is the paperwork shows when you officially brought it into CA. You may already have that date on paper, and that would need to be changed...
It is not against the law for a CA resident to own a non CA certified bike out of state. It is just that a CA resident cannot register a new bike (less than 7500 miles) from out of state, in CA, unless it is CA certified or over 7500 miles.
Currently, the only difference between a 50 states bikes (EPA cert) and a CA certified bike is that the CA cert meets EPA plus it has a charcoal filter for the gas tank vent.
In the past, there were big differences (HP, cam, and others). They even called them 49 state bikes (EPA cert) v 50 state bikes (EPA & CA cert). These registration rules were enacted to keep people from avoiding the CA requirements altogether, by just buying a new bike across a state border and then bring it to CA.
good luck
good luck
Thanks for the info Hattitude!
I went through this about 17 months ago with a bike I had bought in Indiana.
I believe there is a place on the registration paperwork where you can annotate that the odometer is not showing the correct mileage. You can check that part of the form and enter the correct mileage, which will be used for registration purposes.
You never know, maybe she was rebuilt at 3,000 miles. Saves you the cost of dual registration.
