Horn problem on the Heritage
Old Jun 7, 2015 | 08:19 PM
Pete3323's Avatar
Pete3323
Default Horn problem on the Heritage
I just installed the Kuryakyn Mach 2 horn cover on my bike. When I torque down the nut that holds the cover on the horn sounds like a wounded moose! Loosen that nut a few turns and it sounds normal. I have tried spacers and even made a cardboard "gasket" for the rear of the cover where it meets metal. No improvement. The connections are tight, horn is not hitting the cover and no wires touching anywhere. As soon as I tighten that nut, the horn is muffled. Anyone had this issue or have any suggestions? Thanks in advance!
Old Jun 7, 2015 | 09:42 PM
Bone Doc's Avatar
Bone Doc
I'm sure you read it, but this is directly from one of the (3) instruction sheets found on the Kuryakyn website:
https://maggroup.blob.core.windows.n...-21HD-1012.pdf
STEP 10 Test the horn. If the horn sounds muffled, recheck the torque on the nut holding the horn to the new bracket and ensure the bell of the horn is not touching the Mach 2 Cover. If this does not improve the sound of the horn, it may indicate that the horn is damaged and may need to be replaced.
Obviously Kuryakyn is aware of this. This indicates that it is normal and occurs due to:
1. Tightening the nut too much
2. The horn touching the cover
3. Defective horn
Old Jun 7, 2015 | 10:29 PM
Pete3323's Avatar
Pete3323
Yes I read that. The horn is fine as it works perfectly unless the bolt is tightened (as stated). With the bolt loosened to where the horn works properly it is pretty much swinging free so not an over tightening issue. I'll call Kuryakyn but wanted to see if any members may have had this issue. Anyone had any real world experience with this issue?
Old Jun 8, 2015 | 07:29 AM
tbonetony06's Avatar
tbonetony06
Harley horn are a POS imho. I finally put a 2 bugle air horn on mine. I was tired of it working when it wanted too and I got tired of young kids pulling out in front of me when they are on the phone or texting. My air horn sounds like a train!
Old Jun 9, 2015 | 07:30 PM
Pete3323's Avatar
Pete3323
Talked with Kuryakyn today. What they said is that some Harley horns are a little bit bigger than others and I must have one. They have no idea why this is. Said maybe 1 in 1000 horns. Said I could send it back but I do like the cover. Guess I'll try my luck with another horn. Sucks though!
Old Jun 19, 2015 | 08:17 PM
Pete3323's Avatar
Pete3323
So I got a new horn at the dealer. Got the new louder version. Told the parts guy what Kuryakyn said about some being larger..he asked what they were smoking. Anyway....the new horn is better. Not perfect for sure but sounds like a larger wounded moose at least. Frustrating but I guess I'll live with it since I do really like the cover. Gotta say my opinion of Kuryakyn parts has gone down though.
Hrlyrider
Jul 15, 2012 08:01 PM
azzdog
Aug 24, 2011 10:50 AM
steelerdude1
Jul 14, 2011 02:32 PM
tslonige
Sep 26, 2009 08:44 PM
4merfigur8er
Oct 13, 2007 10:57 PM
