Squeaking Baffles
Old Jun 11, 2015 | 04:15 AM
Gibler77's Avatar
Gibler77
Default Squeaking Baffles
Is there something I can wrap the baffles with that will snug up the fit in the pipes?
Just installed LA Choppers 187 exhaust on my Fat Boy, and there's a terrible squeak/chirp coming from loose fitting baffles. I've tightened them up as much as I can, but the noise is still there. I removed them both, and the noise is gone. I prefer to keep baffles in so the sound isn't obnoxious.
Old Jun 11, 2015 | 06:38 AM
cocky's Avatar
cocky
Wrap em with exhaust fiberglass packing. That will probably quiet them down more, however. But should stop the rattling. J&P cycles among other places.
Old Jun 11, 2015 | 09:38 AM
Gibler77's Avatar
Gibler77
Since the ends of the baffles can be the only contact points against the pipes, is it necessary to wrap the entire baffle and lose sound? I'd like to somehow wrap the largest diameter areas (ends) only, so sound isn't affected. Would some sort of silicone tape or even fiberglass exhaust wrap work?
Old Jun 17, 2015 | 08:25 PM
Gibler77's Avatar
Gibler77
Just finished wrapping the baffles with fiberglass packing. The squeak/chirp is gone, but the bike now sounds like a sewing machine. Not gonna work for me, unfortunately. I'll go no baffles, annoy neighbors, and lose back pressure before I allow the Harley to sound like a stock Yamaha V-Star 650.
Maybe I can wrap the baffle with about an inch width piece of packing? Let the trial and error begin...
Old Jun 18, 2015 | 06:04 AM
HDmikie's Avatar
HDmikie
Had the same problem with quiet baffles in my V&H Longshots. What I did was take a vice grip and bend (or flare) the end of the baffle to sort of mushroom the baffle. By doing this the baffle fits tighter in the pipe. It takes a little trial and error but it works.
Old Jun 18, 2015 | 06:18 AM
pipeyeti's Avatar
pipeyeti
Best option
Old Jun 20, 2015 | 11:38 AM
Gibler77's Avatar
Gibler77
Is it necessary to do this with both ends of each baffle?
I contacted LA Choppers technical support, and their suggestion was to live with the sound until the baffles carbon up and it goes away on it's own.
Old Jun 20, 2015 | 12:17 PM
HDmikie's Avatar
HDmikie
I just crimped the end furthest from mounting screw. You would probably have to wait along time for carbon to build up.
jimlowe
Feb 8, 2014 01:37 PM
tomw
May 24, 2011 09:38 PM
FLSTF
Exhaust System Topics
Mar 10, 2009 11:24 AM
wrustywrench
Aug 5, 2006 03:08 AM
heavy hauler
Apr 25, 2006 01:26 AM
